Author: Subject: Can I remove this piece of chassis ?
karlak
posted on 18/8/11 at 07:26 PM Reply With Quote
I am hoping to move my engine back a few inches from where it used to be as a Pinto setup. Obviously to help bring the weight back a tad more central to the car, but also help a bit with the gear shifter being more to hand.
From the picture below, there is a "cross bar" (circled in red) of chassis that would stop/hinder this from happening. Can we really see a problem in removing this? If so, should a new bit be welded perhaps a few inches further forward on the frame ?
any thoughts ? cheers
[Edited on 18/8/11 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
scutter
posted on 18/8/11 at 07:32 PM Reply With Quote
That can be moved further back, i'd suggest fitting another one further forward as well.
ATB Dan.
bi22le
posted on 18/8/11 at 08:13 PM Reply With Quote
I think i would cut it out mount the engine and then add bracing where you can after.
Please read my ring story:
jacko
posted on 18/8/11 at 08:57 PM Reply With Quote
Thats what i did
Jacko
