Author: Subject: How much paint for a 7?
sdh2903
posted on 19/9/11 at 02:04 PM Reply With Quote
As above I'm about to embark on my quest to paint my car, but have no clue with regards to how much paint I need?
I was looking at a 2.5l tin of celly top coat which would give 5l when thinned, does this seem about right for a seven?
Would this be the same if using 2k or will it be less due to fewer coats req?
cheers
jossey
posted on 19/9/11 at 02:06 PM Reply With Quote
should be ok if you dont have to sand and repaint any of the panels.
I painted the bonnet, rear panel, nose cone, wings with 1.5 litres and i messed the back panel up and thats 3 coats.....
David Johnson
cliftyhanger
posted on 19/9/11 at 03:01 PM Reply With Quote
sounds right to me too. 2.5L will do a small car
Daddylonglegs
posted on 19/9/11 at 03:31 PM Reply With Quote
I'm almost at that stage too. Mine is going to be 2-colour, about 55/45 split in terms of area. So I was reckoning on 2L primer, 1L for each of the colours + 5L thinners (I'm using cellulose solid colours). Hopefully it should be enough, but it sounds like I may need to add 1/2L of each colour though.
I was thinking of going with Jaywell Paints in the Midlands, only £9 for postage on that lot
JB
Bare
posted on 19/9/11 at 06:36 PM Reply With Quote
Do note that 'some' colours have bugger all hiding/covering ability,
as in they will either require a Base coat OR 'Several' coatings before what's underneath is no longer visible.
DixieTheKid
posted on 19/9/11 at 07:12 PM Reply With Quote
Have you thought about having it wrapped? No crazing or cracking.... Well within reason.
[Edited on 19/9/11 by DixieTheKid]
COS IT'S Worth IT
sdh2903
posted on 19/9/11 at 07:35 PM Reply With Quote
Cheers thought 2.5l would be enough!
Dixie, I have already wrapped parts of it but am just not happy with the finish, i've had a couple of bits done professionally too to see if it was my fists of ham that was the issue. I also doubt its durability too, i've caught bits when moving around the garage and has just gone through, at least with paint you can polish out/touch up.
