matty h
posted on 27/9/11 at 07:32 PM |
Vinyl wrap
Thinking of fitting vinyl wrap to the sides of my MK sick of polishing them.My question is how easy is it to do yourself as there are lots of sellers
of the wrap on e bay.Just looking at a standard black vinyl.The only thing I am concerned about is how it will cover the rivets on the side panel.
Thanks Matty
joemotion
posted on 27/9/11 at 07:44 PM |
Go with the 3m Di-noc - just done my rear arches in it and amazing stuff. you can get from carbon mods and they do samples so you can test over the
rivets.
Nurburg2006
posted on 27/9/11 at 08:19 PM |
Wrap
I wrapped my whole car in black carbon I drilled out all the rivets covered the panels and replaced the rivets with black ones looks great. I only got
the cheap wrap its fine. I got over 8 meters for under £90 well worth doing. Get a hair dryer soapy water and you will be fine. .
Dangle_kt
posted on 27/9/11 at 10:01 PM |
A pin, a heat gun and a soft cloth are all you need to sort rivet heads.
I did my rear panel (was alu) and it worked a treat. Did my tunnel top too colour matched.
Think it cost £15 for the wrap, but buy a felt block, they are best for smoothing without damaging/ creasing the vinyl.
40inches
posted on 28/9/11 at 08:19 AM |
Di-Noc is the way to go, very durable, molds with a heat gun and no bubbles, has tiny channels on the back that lets the trapped air disperse If
you get it wrong, reheat, pull it off and refit.
DiNoc 3
Carbon fibre?
matty h
posted on 28/9/11 at 05:57 PM |
Thanks for the replys.What do you think a complete side panel would look like in black carbon fibre wrap, would it be too much.
Thanks Matty
StevenB
posted on 4/10/11 at 02:49 PM |
40 inches
by any chance do you have MK carbon fauxber cycle wings
and is the vinyl a good match?
Also what is the 3M code of the vinyl you used.
Looks great. Of the web it looks like CA-421?
40inches
posted on 4/10/11 at 03:55 PM |
quote: Originally posted by StevenB
40 inches
Don't have any Carbon Fibre on the car to compare, but while the DiNoc looks fine as a finish, I don't think it would look
that good along side the real thing, I used it as an alternative to paint or vinyl cloth.
I got mine from
here
It needs 2 coats of clear top coat to get a shiny finish, it comes as mat black.
Hammy360
posted on 11/10/11 at 08:39 AM |
wrap
Thanks Matty
Matt have a look on my site, Ive just done the scuttle, bonnet and interior and the side panels will follow suit now.
I dont think it looks too much
http://hammyszero.blogspot.com
bi22le
posted on 11/10/11 at 09:42 AM |
I did my side panels that were rivered.
i made up a punch tool from a piece of bar. i put the vinal on then puched out a hole around the rivet allowing it to lay flat. Just looks like a
black pannel with silver rivets. by far the best way to finish a rivet fixed panel.
u2u me if you want photos.
hth
Please read my ring story:
Nick DV
posted on 15/10/11 at 11:26 AM |
How does the Di-Noc stuff behave near areas of heat, ie if applied on side panel near exhausts or on bonnets? Just interested cos if it's
applied with heat will it come off or ripple near a heat source?
Cheers, Nick
"The force will be with you, always!"
RK
posted on 15/10/11 at 12:15 PM |
Likely, since it's basically ... er, vinyl. Try it with a heat gun and you'll see it crinkle up into a little ball of crap. One thing you
have to keep in mind with it, is that when you do the edges, heat will shrink it, so if you have white underneath, it can recede enough to leave some
of that showing, looking quite terrible. It really doesn't look the same as real CF, and I don't think, unless they are side by side, they
look too bad on the same car. It's different, and can't be confused by anybody who knows what real CF looks like.
Nick DV
posted on 15/10/11 at 04:20 PM |
That's why I asked, as I know its been used in those areas by some.
Cheers, Nick
