Author: Subject: protecting rod end bearings from road cr@p
Bob C
posted on 6/8/04 at 11:47 AM Reply With Quote
I'd like to keep salt, grit and water out of the 4 rod end bearings on my rear suspension. Something like a steering rack bellows would do this a treat, stick a bit of oil in, tighten up with tiewraps.
Is there anything out there I should know about?
I want fit & forget, minimal maintenance.
Bob C
mangogrooveworkshop
posted on 6/8/04 at 11:51 AM Reply With Quote
You get covers that are made to do that very job>
Bob C
posted on 6/8/04 at 12:05 PM Reply With Quote
from?????????
stephen_gusterson
posted on 6/8/04 at 01:00 PM Reply With Quote
http://www.charit4.org.uk/rotaprecision/motorsport.htm
some people just need spoon feeding
atb
nursie
locoboy
posted on 6/8/04 at 01:38 PM Reply With Quote
some people cant help taking the wee either lol
Thought nursie was a weekend only activity Steve?
Locoboy
Bob C
posted on 6/8/04 at 01:47 PM Reply With Quote
Ta Steve - nearly what I'm looking for.... (those on the site would require re-make of wishbones...)(spits dummy out......)
Bob C
stephen_gusterson
posted on 6/8/04 at 01:50 PM Reply With Quote
colm....
Its Friday..... nearly there!
Bob
did you see both types? the washer ones and the bootee types?
atb
steve
Bob C
posted on 6/8/04 at 02:01 PM Reply With Quote
Yeah mate, but me clevis is a close fit on the ball - I need sommat to go right round the lot! - more of a bag than a boot; I think a wee steering bellows is the answer! TTFN
Bob
Hugh Jarce
posted on 9/8/04 at 01:46 PM Reply With Quote
Those Sealit washers are absolutely useless. Fine dirt does get past them and then it is captive and grinds away at the bearing.
What you are talking about are genuine rod end boots that encompass the whole end, but do not include washers. Rose (as in Rose joints) are the only manufacturer I know of who supply them. They are not very popular because they do not work either. If you use Teflon lined rod ends they are self sealing and the Teflon acts like a wiper on the ball. Nothing is totally grit proof but the Teflon lined ones will outlast any metal to metal joints in a dirty situation. The bronze lined reo ends require oil/grease to lubricate them which attracts dirt and acts like grinding paste. Teflon lined bearings should not be lubricated.
The pay isn't very good , but the work's hard.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 11/8/04 at 12:06 PM Reply With Quote
Rod End Boots
RESB and ABC sell the boots.
I have also tried filling the boots with silicon grease in the past and this seems to help.
F1 Mini
posted on 12/8/04 at 09:18 AM Reply With Quote
Who Are those two companies ?
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
posted on 12/8/04 at 11:47 AM Reply With Quote
Bearing Companies.
www.google.com gives the following:
http://www.resb.co.uk/
http://www.autosport-bearings.co.uk/
They are companies that sell bearings and ones that I have used for years.
John
