Dale
| posted on 8/2/12 at 05:08 AM |
Glue in windscreen
I am trying to layout my windshield supports etc. It will likely be a split screen with the center about 3 inches forward of the sides, and with a
40 degree rake.
If I was to glue\ the glass down as in a modern car, how wide a section would I need to glue down on the edges. If too much I may have to go with
the rubber seals?
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
snapper
| posted on 8/2/12 at 05:46 AM |
Most modern cars, quite wide, usually more than an inch
I eat to survive
I drink to forget
orton1966
| posted on 8/2/12 at 06:04 AM |
Half That
Modern cars use the windscreen to add rigidity to the bodyshell, hence the size of the bonding area. Given you’re just using the adhesive to hold the
glass in, I’d have thought even 1cm would be sufficient, especially if the surround is rebated so the glass sits down flush.
StrikerChris
| posted on 8/2/12 at 10:08 AM |
Did about 10mm on mine,and it hasn't fallen out yet!
Chris
watsonpj
| posted on 8/2/12 at 11:55 AM |
just remember to makesure the glass has a small gap to the frame (see below) when fitted else when you need to replace its hard to cut out with the
cheese wire and damages the surround. Guess how i know.
[img]
  screen_gap
[/img]
regarsd Pete
Dale
| posted on 8/2/12 at 01:55 PM |
As usual thanks a lot for the help. the one cm sounds perfect for the middle as I did not want it to have a wide strip down the center but that would
give me about an inch block out of the center including both sides and the center support.
Dale
Dale
