Author: Subject: Fitting rear wings
puma931
posted on 26/4/12 at 08:09 AM Reply With Quote
Fitting rear wings
Hi, Can anyone advise where to buy the piping used for fitting rear wings to a LC7.
Mathew
wicket
posted on 26/4/12 at 08:22 AM Reply With Quote
Here
http://www.coh-baines.co.uk/
http://www.woolies-trim.co.uk/
steve m
posted on 26/4/12 at 08:25 AM Reply With Quote
I used black door /draft strip, and stuck it on to the wing, once its all clamped together you can hardly see it
puma931
posted on 26/4/12 at 08:31 AM Reply With Quote
Originally posted by wicket
Here
What type of rubber piping should I go for, as there are so many options and my car has nthing so I can't compare.
wicket
posted on 26/4/12 at 08:38 AM Reply With Quote
In the Woolies page go to Rubber then Extrusions, item R615. I used something similar but the tubular parts is 6mm dia. Look in Baines for that.
afj
posted on 26/4/12 at 08:42 AM Reply With Quote
i used woolies part no. r97
eerrrrrrrrrrrrrrrr
Daddylonglegs
posted on 26/4/12 at 09:11 AM Reply With Quote
Yep, ditto
I cut holes out at the points where the bolts go through and small notches (read triangles) to help the stuff follow the curve of the arches.
I think most people on here use that stuff, I think it's called Tadpole Trim?
HTH
[Edited on 26/4/12 by Daddylonglegs]
puma931
posted on 26/4/12 at 10:22 AM Reply With Quote
Thanks for the information.
I just bought this ex-race car and now need to fit all the new panels I bought from Low7man (ebay), who has great prices on nose, scuttle, f&r wings (narrow ones for escotr axle) and rear pannel - £200 for the lot. I will take some pictures when it is all bolted together and looking better than my profile pictures shows.
johnemms
posted on 26/4/12 at 10:35 AM Reply With Quote
VW BEETLE BLACK WING BEADING VW T1 BUG ENOUGH FOR 4 WINGS eBay - The UK's Online Marketplace
puma931
posted on 26/4/12 at 11:25 AM Reply With Quote
Did you use this stuff? if yes, any tips?
Bluemoon
posted on 26/4/12 at 12:55 PM Reply With Quote
Used tadpole piping but not rubber though, stiff PVC type stuff. Used evo stick impact adhesive on wing edge and piping to hold in place, V's cut in a number of places to get a good curve and around bolt holes. The evo stick help in that you can get the wings on and off by unbolting without having to get the radpole trim in place each time..
[Edited on 26/4/12 by Bluemoon]
johnemms
posted on 27/4/12 at 01:48 PM Reply With Quote
Just done my backwings with it .. fab job... pvc .. not stupid rubber
