andy996tt
posted on 6/5/12 at 08:30 PM |
Weber alpha kit
Can anyone confirm if a Weber Alpha ecu takes a feed from a coolant temp sensor. I've got a pre built car and cannot see a sensor for the ecu.
I've also gone through the installation instruction and find no mention of a coolant temp sensor
andy996tt
posted on 6/5/12 at 08:31 PM |
Ps. It's on a ford zetec blacktop engine with a plastic thermostat housing
perksy
posted on 6/5/12 at 08:44 PM |
If its for EFI it will need a Coolant temp sensor otherwise iirc it just drops to a default setting
Wiring diagrams used to be available on the Webcon website
andy996tt
posted on 6/5/12 at 08:50 PM |
Sorry. Should have said
It's got twin carbs
perksy
posted on 6/5/12 at 09:03 PM |
Ahhhh ok then
Are you using the Weber Alpha PI 150 or similar ? Which is just for carb's
ECU doesn't need to know water temp for computing fueling requirements if using carbs
Although it will have an Air temp sensor
loggyboy
posted on 6/5/12 at 09:07 PM |
Isnt alpha for throttle bodies not carbs?
Mistral Motorsport
perksy
posted on 6/5/12 at 09:36 PM |
Weber Alpha did a kit for webers using the PI 150 ECU ( plus another iirc )
It consisted of a pair of 45 dcoes and all the kit (TPS, Air temp sensor etc)
Westfield used to supply them as a complete kit
The catch is that the Early version of this ECU Cannot be re-programmed, not even by Weber Alpha dealers
The Later version of the ECU can be re-mapped though
Weber Alpha is a pretty reliable system
Only problem is its Weber Alpha dealer for mapping ![](/images//smilies/sad.gif)
andy996tt
posted on 6/5/12 at 10:07 PM |
Yep. That's the kit I've got.
Cheers for clearing that up
