MikeFellows
posted on 23/5/12 at 10:43 AM |
Attaching scuttle mount mirrors
when attaching mirrors to the scuttle, do you guys put anything behind the GRP to make it a bit stiffer
I was thinking of bonding a plate to the inside of the scuttle to keep it a bit more ridgid.
is it neccessary?
using ZZR1400 mirrors if it makes a difference
Daddylonglegs
posted on 23/5/12 at 11:02 AM |
I'm using R1 mirrors and put a 3mm 1" x 3" plate behind mine just for a bit of support. Should be fine as the scuttle is quite thick
anyhow.
HTH.
deezee
posted on 23/5/12 at 11:26 AM |
I made a little aluminium block (flat on one side, scuttle profile on other) to square off the inside of the scuttle, so the nut didn't dig into
the scuttle.
wicket
posted on 23/5/12 at 02:21 PM |
I have all.al. plates on the inside with rivet nuts to suit the mirror fixings, work fine no serious vibration problems.
lewis
posted on 23/5/12 at 06:15 PM |
I have big alloy plates on the inside & carbon fibre plates on the outside all bolted through the scuttle it's really solid no vibrations or
problems.
I am a driving god!..........sort of
