Author: Subject: Wiper arms.
stevem427
posted on 8/7/12 at 12:28 PM Reply With Quote
Wiper arms.
Afternoon all. Im after a bit of advice on what wiper arms i need. The wiper motor is a Sierra unit.All fitted and working. What arms do i need. The motor parks the wrong way for the angle of sierra arms.Just wondered what others have done regarding arms and blades.Cheers Steve.
Macbeast
posted on 8/7/12 at 01:45 PM Reply With Quote
I used MG Midget arms and blades They park in front of the driver.
stevem427
posted on 8/7/12 at 01:55 PM Reply With Quote
Thats the trouble im having. The Sierra ones are bolted on with a 13mm nut which goes through the arm,and i think the Mini/MG ones are push on. And i need them to park in the passenger position. Cheers Steve
Chippy
posted on 8/7/12 at 03:08 PM Reply With Quote
I did the same ,(silly), thing, and used the modified wiper motor from the Sierra. The only way I could get any arms to fit was to buy some sierra arms, alter them for length, (real pain), and rebend the arms to lay correct way on the screen. Then locate some ten inch blades from Ebay. Should have spent the extra and fitted mini ones. HTH Ray
stevem427
posted on 8/7/12 at 03:33 PM Reply With Quote
Cheers Ray. Its easy to be wise afterwards. I better get looking for some Sierra arms and some 10" blades then.Cheers Steve.
posted on 8/7/12 at 05:17 PM Reply With Quote
Might be worth putting the end of the wiper arm in a vice and gently bending to the required angle?
