The Simmonds
posted on 17/7/12 at 10:21 PM |
Oil cooler kit and engine mounts - ford pinto
Hi does anyone have any engine mounts or an oil cooler kit that will fit a ford pinto engine? Many thanks
Matt
AdrianH
posted on 17/7/12 at 10:39 PM |
Is the Pinto fitting 3/4UNF?
I do not have one to hand but I am purchasing a kit for my CVH at present.
Getting a oil sandwich plate with a stat, 13 row oil cooler, oil pipe fittings and 2 metres of tube for £103.65
Here is breakdown
1 x Oil cooler sandwich plate with stat (3/4unf) @ 42.95
1 x 13 row oil cooler @ 27.00
1 x pair 1/2" female connectors for oil cooler (ebay 330492294320) @ 4.95 pair
1 x pair 1/2" male connectors for sandwich plate (ebay 330624861990) @ 5.95 pair
2 x mtrs 1/2 hose (ebay 370475024443) @ 6.50/mtr = 13.00
4 x hose clips for hose @ 0.95 each = 3.80
Oil pipe can be pushed on to connectors and tightened with jubilee clips above.
*Carriage 3-5 day @ 6.00
If you look at the ebay items you will see who.
Not sure if it is what you are after.
Adrian
Why do I have to make the tools to finish the job? More time then money.
The Simmonds
posted on 17/7/12 at 11:13 PM |
Hi Adrian,
Thanks very much for your reply. Yes I have seen that on ebay. Looks great but a bit pricey for a poor student! I was wondering if anyone had anything
second hand for a bit cheaper.
Thanks all the same though!
Matt
snapper
posted on 18/7/12 at 06:18 AM |
From bitter experience
Don't scrimp on the pipe clips
At a minimum us Mikalor clips the ones with bolts to tighten, I had a standard jubilee clip slip off at speed lost all oil pressure at 80+ mph, by the
time I switched off virtually no oil left and the mess took weeks to clear up.
Now have pipes with swaged fittings
I eat to survive
I drink to forget
HomersDouble
posted on 18/7/12 at 07:48 AM |
I have a pair of the std Ford cast ally ones & metalastic mounts you're welcome to if thats what you are after?
Yours the the postage costs (quite heavy though......)
Chris
