puma931
posted on 17/10/12 at 06:01 PM |
Fitting front wings
Is it possible to fit front cycle type wings withought using bolts i.e. bond it to the metal supports? Has anyone done this? if yes, how did you do it
and how long has it lasted??
steve m
posted on 17/10/12 at 06:21 PM |
Yes it is possible, and yes i have, 13 years so far
mums the word!
puma931
posted on 17/10/12 at 06:22 PM |
What did you use and how did you do it?
mums the word!
steve m
posted on 17/10/12 at 06:37 PM |
Only joking!!
firstly i made the bars out of of 5x25mm flat steel bar, any thiner will break
Secondly, apply araldite or similar two pack adhesive to the top of the bars (that the mudguards sit on)
place them exactly were you want them, and wait to cure,
take of whole mudguard assembly, and flip over, then apply fiberglass matting over the bars, and on two the mudguards
Job done
12000 miles later, ive not lost one yet!
However, now and again, when i take the guards off i do give it another fiberglass matt over the bar, just for security!
patent pending
regards
steve
puma931
posted on 17/10/12 at 06:46 PM |
Great. Thanks.
Only joking!!
Job done
patent pending
regards
steve
johnemms
posted on 17/10/12 at 06:52 PM |
I've used window screen adhesive .. strong stuff..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
daviep
posted on 17/10/12 at 07:03 PM |
I just used sikaflex (or similar PU adhesive), couple of really big thick strips on the top of the mudguard support, tape two wooden blocks on to the
tyre (front and back) to ensure the mudguard follows the line of the tyre, then just lay the mudguards on to the supports/blocks and leave to set.
Need to make sure the mudguard is given a very good clean / key up whre the adhesive will be.
Davie
Pdlewis
posted on 18/10/12 at 08:18 AM |
I bonded angle ali on to the cycle wings with windows screen adhesive then bolt into the wing stays, this provides some shock buffering and done see
any of the surface cracking alot of people experience
Build Photo Album
Updated 05/02/2009
welderman
posted on 18/10/12 at 09:50 AM |
arch
i used PU on my Front arches, works a treat
Thank's, Joe
I don't stalk people
loggyboy
posted on 18/10/12 at 09:58 AM |
I asume you dont want to use bolts to avoid the unslightly finish they give?
If so try the 'big heads' described here
http://locostbuilders.co.uk/viewthread.php?tid=173363
http://www.bighead.co.uk/english/products/standardbigheads.html
Mistral Motorsport
