scoobyis2cool
posted on 16/9/04 at 04:02 PM |
Fixing nose grill
At the moment my nose grill is held on by 4 blocks, equally spaced on the inside of the nose cone, grill placed against them and bolted through into
the blocks.
The other day i took my car for its first drive and when i pulled back onto the drive i noticed the grill rattled quite loudly over bumps as it
vibrated where it isnt directly bolted.
How has everyone else mounted their grill so that it doesnt rattle?
Pete
locoboy
posted on 16/9/04 at 06:51 PM |
What type of grill is it? MK or a home made jobbie?
Locoboy
scoobyis2cool
posted on 16/9/04 at 10:48 PM |
It's a home made thing, quite a fine mesh that I got from B&Q much cheaper than you can buy "air vent mesh" from places like
demon thieves
Pete
posted on 16/9/04 at 11:31 PM |
I bent mine round the lip on the nosecone then glued it in place with bodyfiller all round. It holds it nicely in place.
zetec
posted on 17/9/04 at 06:56 AM |
Four holes, one top/bottom and each side and cable tie on.Get the right colour and you don't notice them. Easy to get it nice and tight and
rattle free.
RoadkillUK
posted on 17/9/04 at 12:49 PM |
my brother did ours, it's mesh from B&Q, used a similar method, instead of block of wood he used aluminium angle and layed the mesh on top
and then Araldite (sp?) to hold it on, only been approx. 100 miles with it but there seems to be no problems.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Chris_R
posted on 18/9/04 at 11:47 AM |
You could use P40 fiberfglass compound. Place big blobs of the stuff around the inside of the cone, drill a pilot hole and screw through the mesh with
small self-tappers. Don't think it'll go anywhere and you can put in as many fixings as you like.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
macspeedy
posted on 18/9/04 at 08:23 PM |
i bought a lolocost grill for my mk nose cone made up some small pieces of 20mm 3mm flat bar drilled a hole and brazed them in place once cool used
some black silicon sealent to hold the grill in place has worked a treat!!
posted on 18/9/04 at 09:41 PM |
Mesh and PU Adhesive.
From inside the nose cone - bend mesh around the outside lip of the cowl.
PU Adhesive all the way around secures it wonderfully!
[Edited on 18-9-04 by Hellfire]
