neilp1
| posted on 17/11/12 at 08:05 PM |
Repairing fibreglass
The rear of my tiger has been rear ended resulting in damage to the fibreglass.
Is it worth repairing bearing in mind it is all in one, sides, rear tub, rear arches, scuttle or just buy another tub which cost 800 quid.
Cheers Neil
Wheels244
| posted on 17/11/12 at 08:17 PM |
If they're paying Neil, why not go for the new tub - would be much better than a repaired one.
snakebelly
| posted on 17/11/12 at 09:31 PM |
That's the key, are they paying or are you?
neilp1
| posted on 17/11/12 at 11:46 PM |
Me will be paying
snakebelly
| posted on 18/11/12 at 09:26 AM |
Lets have some pics then, think I can help with the wings I have moulds for extended wings in the workshop that will bolt on
neilp1
| posted on 18/11/12 at 09:42 PM |
Pics of damage.
As you can see from the pics there is no damage to the rear wings.
Jimfin
| posted on 19/11/12 at 11:26 PM |
Neil,
It looks pretty superficial from the pics and would be readily worked out with some reinforcement behind the panel and finished with gel coat in the
visible area. You would need a RAL code to get the gelcoat matched.
Jimfin
| posted on 19/11/12 at 11:30 PM |
Just saw your location - speak to these guys in South Shields -
http://www.ecfibreglasssupplies.co.uk/default.aspx
They will sort you out with advice and materials.
snakebelly
| posted on 20/11/12 at 09:07 AM |
Agreed, pretty superficial by the looks of it, should be possible to repair without removing it with a bit of patience, must have been a light tap!
Shame your not closer as the fibreglass chap in the unit next door could have done that for you
40inches
| posted on 20/11/12 at 10:24 AM |
As an alternative,if there is a Marine workshop near you, they will do a terrific job at a lot less than replacement.
| posted on 20/11/12 at 10:33 AM |
Speak to Andy mate, he knows a bloke who can fix that..
