Author: Subject: MK Indy Sump Guard?
smitht82
posted on 23/11/12 at 05:31 PM Reply With Quote
MK Indy Sump Guard?
Does anyone know of anywehere i can get a sump gaurd from as the R1 engine is a little exposed? If not then i will go to the local fabricators and see if they can make one.
renetom
posted on 23/11/12 at 05:44 PM Reply With Quote
skids
Hi
I just made a pair of skids using steel strips a lenght of shallow unistrut & fittings
Only needed to drill 2 holes in the steering rack support. Job done.
You only loose around 12mm clearance , maybe less. & much better than a sump guard, just lifts up the front & no damage.
& I guarantee it works , from experience.
René
[Edited on 23/11/12 by renetom]
adithorp
posted on 23/11/12 at 10:05 PM Reply With Quote
Pictures of my R1 sump guard (more like a skid) is pictured in THIS thread.
http://jpsc.org.uk/forum/
