Author: Subject: Catering van nosecone ?
Jon Ison
posted on 27/1/13 at 08:34 PM Reply With Quote
Straight swap for a locost one, are the dimensions close enough, anyone fitted one to a locost chassis !
Ben_Copeland
posted on 27/1/13 at 08:42 PM Reply With Quote
I had one on my old locost. Seemed to line up ok
Front End 24/7/04
Front End 24/7/04
[Edited on 27/1/13 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
Surrey Dave
posted on 27/1/13 at 09:53 PM Reply With Quote
Yep.
Thats what I have, you just need to trim the side shape so that it sits flat on the chassis.
I think you will find that it gives the lowest bonnet line of all the options, so if that is tight you may have to measure.
Remembering from a very long time ago I believe the back edge of the cone to be 5.5" above the top chassis tube. but i should check on that yourself if it is crucial to your design.
[Edited on 27/1/13 by Surrey Dave]
Jon Ison
posted on 27/1/13 at 10:06 PM Reply With Quote
Thanks for that, could you at your leisure measure and confirm the 5.5 inch ?
Does/can anyone tel me the height of a catering van scuttle from the top chassis rail, engine side ?
Surrey Dave
posted on 28/1/13 at 12:46 PM Reply With Quote
I Lied!!!
Have been out to measure, I have a Caterham Nose & Scuttle................
Scuttle engine bay side height = 8.5" above chassis top tubes
Nosecone front bonnet lip = 6.75" above chassis top tubes
