pekwah1
| posted on 18/4/13 at 03:54 PM |
Cycle wings and IVA.
Hi guys,
If my cycle wings touch my side panel (only just) on full lock, is this likely to fail IVA?
It is not restricting the movement at all.
Thanks,
Daddylonglegs
| posted on 18/4/13 at 04:02 PM |
It will probably depend on your IVA centre, but don't forget that the wheels will be up/down from that position and it looks like it may be
closer under droop?
Just my 2p worth
[Edited on 18/4/13 by Daddylonglegs]
| posted on 18/4/13 at 04:12 PM |
Easy enough to pull the steering rack gaiters back and a fit a pair of lock restrictors.
loggyboy
| posted on 18/4/13 at 04:16 PM |
Couldf you try and relocate the wings so that they angle away from the base of the tyre, whilst keeping the tyre coverered!
Mistral Motorsport
40inches
| posted on 18/4/13 at 04:26 PM |
That's what I did, got the collars from RS.
steve m
| posted on 18/4/13 at 05:15 PM |
Or the easy cheat is, pull back the steering gaiter, and stick a small jubilee clip over the steering rod and tighten up TIGHT, and cover in
insulating tape to avoid it chaffing the steering gaiter
you will of reduced the steering movement by 1/2 and inch,
steve
pekwah1
| posted on 18/4/13 at 05:36 PM |
Nice one thanks guys.
I will opt for the cheapo jubilee option, this is Locost after all!
steve m
| posted on 18/4/13 at 05:48 PM |
and your my mate
theduck
| posted on 18/4/13 at 06:22 PM |
40inches - thanks for posting the photo, had read about doing this and wasn't sure where they needed fitting. Makes sense now though and
another job for the list.
40inches
| posted on 18/4/13 at 06:47 PM |
Your welcome
striker-4age
| posted on 18/4/13 at 07:50 PM |
Where do you get them collars ? I need to do this to my striker
40inches
| posted on 18/4/13 at 08:05 PM |
RS Components, look for double split collars.
saxoboy
| posted on 20/7/13 at 11:04 AM |
Hi 40inches
Just out of interest what size collars did you buy? I have just measured my steering shaft and it's 18mm the closest sized collars at rs are
16mm or 20mm.
The reason I ask is, I built my striker 8 years ago and absolutely love it...however I was at rockingham yesterday on a track day and at 3pm I lost
turning left. I had to get my little car towed home on a trailer that I had to hire. I used the cheap and now I find out rubbish method of the jubilee
clip that got mangled in the rack and broke thus stopping me turning left....very scary when your entering PifPaf at 50mph which is a long drawn out
fast left!!
Thanks in advance
Matt
