shaywez
posted on 4/10/04 at 07:17 PM |
bodywork
Hi, can anyone tell me if i need to put a rubber strip between my nose cone and chassis, as well as my bonnet and scuttle. My thinking is that this
would reduce any possible vibration later on. Any thoughts?
RoadkillUK
posted on 4/10/04 at 10:51 PM |
We used 3mm thick self adhesive closed cell foam strip 25mm wide on ours and there are no rattles from the scuttle or the nosecone.
HTH
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 5/10/04 at 08:22 AM |
I'm planning to do the same with the nose, bonnet and scuttle if that's any help!
I fgured it would reduce the chances of rattles and vibration and also protect the paint on the chassis.
Nick
marcotuinenburg
posted on 5/10/04 at 11:07 AM |
Where did you buy it ?
I can't find a company in Holland that sells it.
shaywez
posted on 5/10/04 at 11:58 AM |
cell foam
You can get 19mm x 3mm self adhesive grey closed cell sponge from car builder solutions (www.nfauto.co.uk).
splitrivet
posted on 6/10/04 at 08:38 AM |
Try an air condioning/refrigeration or heating suppliers its widely used in these trades.
Bob
Chris Green
posted on 6/10/04 at 10:16 AM |
Bob
Yes, we get ours from a company called Albert Jagger. I believe their part number is RA25.
Basically its a Closed Cell Polyurethane Foam with an S/A backing. 25mm Wide and approx 3mm Thick. The type we get is black, in 10m rolls, and its
VERY cheap!
Closed cell will be better than open cell, as it will not absorb water.
Regards,
Chris.
[Edited on 6-10-04 by Chris Green]
shaywez
posted on 6/10/04 at 10:39 AM |
closed cell foam
Chris, have you got there contact details
Chris Green
posted on 6/10/04 at 11:51 AM |
yes, I've got the web address...
Albert Jagger
Hope this helps,
Chris.
