givemethebighammer
posted on 6/10/04 at 09:32 AM |
type of mask to use with 1K acid etch primer ?
What sort of mask should I use with the above ?
organic filters
inorganic
something else
do I also need goggles ?
stephen_gusterson
posted on 6/10/04 at 09:41 AM |
mark allanson is your man
Mark Allanson
posted on 6/10/04 at 06:22 PM |
organic, inorganic is for dust etc, organic for fumes
givemethebighammer
posted on 6/10/04 at 09:11 PM |
thanks Mark,
While I have your attention I have a few more questions.
1. I just need a light coat of the etch primer right ?
2. Do I need to sand the etch primer down before applying a coat of normal primer on top ? (do I need the normal primer)
3. How long does the etch primer take to dry before I can move on to the next coat of whatever.
thanks
Mark Allanson
posted on 7/10/04 at 05:15 PM |
1, you need a continuous coat, but the lighter the better
2, no, (only if you get a run, see 1,)
3, read the tin, but usually about 30 mins
givemethebighammer
posted on 7/10/04 at 07:12 PM |
Thanks Mark
no info on the tin about drying time, but it is a fairly plain "for professional use only" aerosol, so perhaps they manufacturer assumes
you will already have this info. If I leave it 24 hours (I'm in no hurry) should be long enough.
thanks
again
