Dooey99
posted on 12/5/13 at 09:43 PM |
side panels HELPPPP
right getting F*cked off trying to find fibreglass side panels for my ron champion kit car, its getting to the stage where i need them.
i have decided to have ago at making some out of aluminium...
i can sort of see how id do it but i plan to get it all bent by a metal work company so the bends are lovely...
a little confused about the side of the engine bay, as the bottom of the engine bay is narrower than the top do i have to sort of put a twist in the
sheet on this bit? how have other people done it? lots of photos would be greatly appreciated.
i want to do each side in one piece to make it look smoother.
PLEASE HELP
Less weight more speed, more power more speed
If in doubt, give it a clout
DavidM
posted on 12/5/13 at 10:01 PM |
I kept the side panel vertical over its full length with a short fold on the top edge over the top chassis rail and a tapering fold on the bottom edge
increasing towards the front of the chassis to reach the bottom chassis rail. I also bent a 45 degree taper into the bottom of the panel give a bit
more shape towards the nose cone, although some others have curved the bottom of the panel as the "book" shows.
[img]
Fitting Side panels
[/img]
HTH
Proportion is Everything
Dooey99
posted on 12/5/13 at 10:09 PM |
What thickness aluminium did you use?
twybrow
posted on 12/5/13 at 10:10 PM |
I attached at the top rail, and then used some straps to pull it in at the bottom, and then used a rubber mallet to fold up the bottom edge. Think
also about whether you want vented front panels. I made one of mine vented, and it dropped under bonnet temperature, and stopped the bonnet lifting at
speed!
DavidM
posted on 12/5/13 at 10:13 PM |
I used 1.5mm because I managed to pick some up cheap, but if I had my time again I'd use 1.2mm.
mark chandler
posted on 12/5/13 at 10:14 PM |
I cut triangles of Ali which follow the middle tubes to the front so the panel is straight and fits flush with a widened nose cone.
Finished front
It does make cutting the holes for the wishbones more awkward so I made a lap joint 3/4 the way down after I mucked the first set of holes up.
designer
posted on 12/5/13 at 10:48 PM |
If you want fibreglass, lay some out on a sheet of melamine and cut to size.
