Author: Subject: Kitchen made splitter - big pictures
Theshed
posted on 21/5/13 at 08:46 AM Reply With Quote
I have embarked on making an undertray running the whole length of my car. I was just going to use plywood but I got ambitious and found some cheap(ish) kevlar.... I made a few practice bits using vacuum bagging. It is not as easy as the interweb tends to suggest and I messed up a few parts. But having just about succeeded with a dashboard I decided to make the front section...pictures below.
First I used a wooden board to mark out the mounting points. I put aluminium inserts in the board and bolted it to the car to test. I then put a Polypropelene sheet over that and drilled through. Inserts were turned up out of Aluminium (7075T6 - bar ends from ebay). I used the remainder of the sheet to form the edges of the mould and then uses wax (the yellow stuff) to make a fillet. This is what the mould looked like once the part was out.
I then used carbon fibre and Kevlar to laminate. This was by far the biggest thing I have done with composites and it took nearly 2 hours to lay up - all the time I was paranoid it would start to go off. Between the laminate I used PVC foam to provide reinforcement. This is good stuff - I was able to sand and shape the edges to match the wax fillet and to make it easier to lay over the fabric by rounding the edges.
I then stuck the whole thing in a vacuum bag
Front splitter/undertray
It leaked! I had run out of the breather fabric and had not covered all the sharp edges. Much gum tape later and it held a reasonable vacuum. Small problem was that it was now 10pm - family a little ratty that I refused to turn off the vacuum pump all night - on the bright side the cat did return today..
The moment of truth last night
First off with the bag and peel ply
Then out of the mould - small problem whilst the part just fell off the polypropelene (no wax at all) I had bonded the polypropelene with hot melt glue around the outside. The excess fabric was shall we say very well bonded....I cut it off with a dremmel. After that it just popped out. What appear to be scratch marks are actually just sticky masking tape that I wrapped around a ruler to prise the part out. It polished off (phew).
I have done a rough trim so far - I had to use the cutting disc in the angry grinder. I then fitted the support frame just to make sure that it would fit. It did!
I am really pleased. I know that a front splitter is generally considered a disposable item and so Carbon fibre is a bit OTT but hey so is the rest of the car. All the materials together were just over one build your own sportscar.
I will bond this section to the next 1m wide section using glass reinforcement so that as and when it gets bashed to bits ripped off etc I can just saw off the front and make another one. Now I just need to find somewhere to put the mould.
I will put some helicopter tape on the underneath to see how long that lasts..
mookaloid
posted on 21/5/13 at 08:51 AM Reply With Quote
Good work
twybrow
posted on 21/5/13 at 08:56 AM Reply With Quote
Nice effort! That is carbon - not Kevlar (unless you have sandwiched the Kevlar under the carbon?)...
If you make another, I would suggest you try resin infusion - your part will be higher quality (fewer voids) and it is likely to be lighter (less resin rich than hand laminating/vacuum bag).
Good job!
Theshed
posted on 21/5/13 at 09:00 AM Reply With Quote
Too scared to try infusion! I get too many leaks. The laminate is carbon x 2/kevlar x 2 /carbonx2. Cutting Kevlar is such fun...
imp paul
posted on 21/5/13 at 10:35 AM Reply With Quote
nice work very cool
jossey
posted on 21/5/13 at 10:39 AM Reply With Quote
Looks great
David Johnson
maccmike
posted on 21/5/13 at 11:19 AM Reply With Quote
thats awesome, I know who'll Ill be ringing when I need one...
omega0684
posted on 21/5/13 at 12:22 PM Reply With Quote
@ TIMMY
Could you make one at work?
FuryRebuild
posted on 21/5/13 at 01:00 PM Reply With Quote
Nice work - it encourages me to do some bits of my own in carbon.
www.furyrebuild.co.uk
twybrow
posted on 21/5/13 at 01:43 PM Reply With Quote
@ TIMMY
Yes mate - my boss is very receptive to little side projects (he has a kit car himself)... We are moving into our new building (office + workshop) next month, so the projects will pick up after then!
And I just took an enquiry for us to design and build CF wheels (automotive) - hmmmmm!
omega0684
posted on 21/5/13 at 02:07 PM Reply With Quote
Originally posted by twybrow
@ TIMMY
Put me down for a set, i can send you dimensions!
coyoteboy
posted on 27/5/13 at 11:33 AM Reply With Quote
That looks nice! I'd be worried about infusion on such a flat wide piece personally, because I've never done it, any tips add to how to ensure a complete infusion up to corners etc?
PS hope you are wearing appropriate PPE when cutting/grinding carbon!
[Edited on 27/5/13 by coyoteboy]
Theshed
posted on 27/5/13 at 12:06 PM Reply With Quote
Errrm cutting in the garden and keeping my mouth closed??? More seriously I must get some masks and glasses - I did get some bifocal safety specs which are very good for machining (you can read a micrometer) but.....sat on them.
coyoteboy
posted on 27/5/13 at 12:16 PM Reply With Quote
Carbon fibres, especially those cut with a grinding tool rather than a saw and water, produce fibre dust with similar properties to asbestos.
http://www.aerotherm.co.uk/the-hidden-dangers-of-carbon-fibres
Theshed
posted on 27/5/13 at 12:55 PM Reply With Quote
Oh dear
That said given that most of my education was in post war portacabins I am probably screwed anyhow. That and I worked in a garage for years blowing out the brake dust and working alongside the sprayer blasting out 2 pack....... No, I know I will get some masks.
coyoteboy
posted on 27/5/13 at 06:14 PM Reply With Quote
Don't worry, I've done the same too before it was pointed out to me by a H&S manager at a place of work - there must be millions of us!
Probably not a problem but worth taking reasonable precautions.
