Author: Subject: Seven Body Panels (Ali)
Tralfaz
posted on 14/10/04 at 03:02 AM Reply With Quote
Finally....... getting ready to start thinking about panelling the chassis.
Question is, what is generally used for:
Floor - ( I would prefer to use Ali over the Locost style welded in floor)
Sides -
Tunnel -
Gauge,Type,etc.
Thanks,
Brian
posted on 14/10/04 at 07:52 AM Reply With Quote
Brian,
I've used 1.5mm Ali fixed with PU adhesive and pop rivets every 50mm.
If building again I would probably stick to 1.5mm for the floor, but use 1.2mm for the rest as it would be slightly easier to cut and bend.
HTH
Nick
Tralfaz
posted on 15/10/04 at 11:27 AM Reply With Quote
Thank You Nick.
Has no one else panelled their cars?
Regards,
Brian
mookaloid
posted on 15/10/04 at 11:50 AM Reply With Quote
I cheated and used MK Fibreglass
DaveFJ
posted on 15/10/04 at 12:01 PM Reply With Quote
I have used 2.6mm duralumin sheet (aluminium alloy - got it for beer) for the floor.
all other internal panels are in 1mm ally sheet.
the Avon has a grp body so I have no external paneling as such
All attached with structural blind rivets at 20-30mm (dependant on rivet size) spacing, in staggered rows and bonded with PU adhesive
HTH
[Edited on 15/10/04 by protofj]
Dave
craig1410
posted on 15/10/04 at 12:07 PM Reply With Quote
Steel floor (1.6mm mild steel) and 1.2mm aluminium (5251-H22 alloy) for the bodywork. Easy enough to bend (just) and very resistant to dents.
I've used Polyflex PU adhesive and pop rivets every 50mm for the bodywork.
Craig.
midlifecrisis
posted on 25/10/04 at 03:24 PM Reply With Quote
Excuse my ignorance .Whats PU ADHESIVE ,WHY'S IT BETTER?
indykid
posted on 25/10/04 at 03:35 PM Reply With Quote
poly urethane. aka sikaflex in its most common guise.
it's so good cos it sticks like the proverbial to the blanket
tom
craig1410
posted on 25/10/04 at 03:56 PM Reply With Quote
Yes and it doubles as a good sealant as well to keep the water and dirt out of your seams.
Craig.
midlifecrisis
posted on 25/10/04 at 08:08 PM Reply With Quote
Ah Sikaflex! Cheers guys!
Rob Lane
posted on 25/10/04 at 09:06 PM Reply With Quote
If you go ali route, take a look at fixing both floor and sides in one go.
i.e. one rivet holding both floor and side panel if folded over.
