Author: Subject: Scuttle mounting
posted on 22/10/04 at 08:04 PM Reply With Quote
Scuttle mounting
I'm about ready to mount the scuttle, but have started to wonder what's the best way to do it.
I am thinking of putting some M6 rivnuts in the chassis top rails and then bolting the scuttle down. What have other people done?
Nick
derf
posted on 22/10/04 at 08:08 PM Reply With Quote
I used 4 dzus fasteners, they worked great, I was a little unsure of how well they would hold it down, but they work wonderfully.
posted on 22/10/04 at 08:10 PM Reply With Quote
derf,
is yours scuttle fibreglass or ali/steel?
Nick
derf
posted on 22/10/04 at 08:34 PM Reply With Quote
fiberglass, built by CMC North america
greggors84
posted on 25/10/04 at 05:20 PM Reply With Quote
Nick
This is what i plan to do with mine, dont see why there would be a problem as long as you use a decent sized washer to spread the load on the fibre glass
Chris
The Magnificent 7!
Cita
posted on 25/10/04 at 06:37 PM Reply With Quote
What are you planning to do Chris?
posted on 25/10/04 at 07:15 PM Reply With Quote
The same as Nick
posted on 25/10/04 at 10:02 PM Reply With Quote
I've done mine as described with 3 x M6 rivnuts in the chassis top rails each side. The scuttle is then bolted on with M6 cap heads and penny washers to spread the load. It seems very secure!
I drilled the holes in the scuttle to 8mm dia. to give some adjustment which allows you to get the edges nicely lined up with the side panels.
Pics to follow shortly.
Nick
James
posted on 26/10/04 at 09:52 AM Reply With Quote
Has anybody who's fitted the scuttle with Rivnuts also fitted a windscreen?
Reason I ask is that I've heard (in other applications) of Rivnuts being pulled out of the tube. I just wonder if they'll be strong enough once the windscreen is bolted to the scuttle and they have to battle with the wind resistance on the windscreen.
James
