nick-york
| posted on 8/11/13 at 10:04 PM |
i dont believe it !!!
Well i was looking round the car a couple of days ago and noticed something really bad ! And now its worrying me ! I noticed that when the seats are
in position the harness mounting points on the roll bar don't line up at all ! They are way out . Now i think it must be a design fault with the
harness mounting put in the wrong place .The seats are very narrow but are a very tight fit so no chance of adjustment there .As far as i can see the
only possible thing to do would be to drill some new holes in the roll bar and reposition the mountings . What a pain ! Has anybody else had this
problem ? Would it be easy to deposition the harness mounting ? Help and ideas needed again please ? See the photo in my archive .
[Edited on 8/11/13 by nick-york]
Wheels244
| posted on 8/11/13 at 10:08 PM |
Put some pics up Nick and we'll have a look - nothing is insurmountable.
ReMan
| posted on 8/11/13 at 10:09 PM |
Define way out?
OCD visual way out, or bad mechanical failure way out?
www.plusnine.co.uk
nick-york
| posted on 8/11/13 at 10:13 PM |
Hi ! I forgot to say I've put a picture into my photo
archive . Not worked out how to get them onto here yet !
ReMan
| posted on 8/11/13 at 10:19 PM |
  Description spot the problem !
Cut off the roll bar and start again
Its the Cobras that are making it wrongest
I suspect the holes were for low back seats, which would have been barely noticeable across a person.
I agree they are going to chafe!
www.plusnine.co.uk
Wheels244
| posted on 8/11/13 at 10:26 PM |
Is the roll bar painted or powder coated ?
If painted - weld up and grind flat the existing mountings, then drill new holes in line with the seats and weld in new threaded tubes. If it's
powder coated, could still do the same, but it will wreck the powder coating.
Wheels244
| posted on 8/11/13 at 10:28 PM |
Or get harnesses that wrap around the bar.
nick-york
| posted on 8/11/13 at 10:39 PM |
Well when i bought all the bits and pieces for the car many moons ago it came with low seats with no headrests so i suppose the mountings would of
been ok for them before the headrest rule came in. As for paint or powder coat on the roll bar im not sure. How could i tell the difference ?
nick-york
| posted on 8/11/13 at 10:42 PM |
would these be iva friendly though ?
johnemms
| posted on 9/11/13 at 11:06 AM |
  REAR VIEW SEAT BELT
Mine looked good with a nut welded in till I had to take them out
and drill 'all' the way through and insert a 'full threaded tube' for IVA..
Yeahh.. feeling your pain..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
| posted on 9/11/13 at 02:26 PM |
If you don't want to attack the roll bar, it might be possible to make a bracket (effectively just a flat bit of mild steel of suitable
thickness) that bolts onto the existing mounting holes, but provides two new points that are in-line with the seat slots.
jacko
| posted on 9/11/13 at 05:25 PM |
To me the tube looks to be in the wrong place too how would the belts go though the seat without pulling at the seat and rubbing on the seat holes
If you can weld how about replacing the tube and putting the belt mounts in the right place
Jacko
Not Anumber
| posted on 9/11/13 at 06:04 PM |
You could just ignore the roll bar and weld short vertical tubes to the chassis rail below. Works well on Mks and some others.
Smoking Frog
| posted on 9/11/13 at 07:58 PM |
The height looks good, grind off, weld the holes up, drill and fit new threaded tubes that goes all the way through. Access would be limited but
maybe not impossible. If you can't get a drill in, remove that section of roll bar and fit a new piece (CDS tube) with the threaded tubes in
the correct position. Whatever you decide you life may depend on it!
nick-york
| posted on 10/11/13 at 01:42 PM |
quote: Originally posted by johnemms
  REAR VIEW SEAT BELT
well im going to cut off the old bits and weld them up and drill some new holes and weld some threaded rod in like
you did if i can get the drill in ok. Could you tell me where you got the threaded rod from and is it ht steel ? Cheers !
Smoking Frog
| posted on 10/11/13 at 02:15 PM |
What you need is 7/16" UNF threaded tube, but get that confirmed. There's usually some on eBay.
