davidimurray
| posted on 31/1/14 at 02:04 PM |
Rear Mounted Fuel Fillers
My fuel filler is on the back of the my car and as is typical I have to dribble the fuel in to stop the petrol pump clicking off. Looking under the
wifes car the other day I noticed two pipes from the fuel filler, one is the actual fuel filling line, the other comes back from the tank and joins
the main fuel filler right at the top. Is this a vent to stop the pump clicking off?? Could the same be done with our cars, i.e. install a vent line
from the tank back to the top of the filler (higher up than where the end of the petrol nozzle sits). Anyone tried this?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
PAUL FISHER
| posted on 31/1/14 at 02:28 PM |
Yes Westfield do, all there tanks come with a one way vent valve fitted in the top corner of the tank.
davidimurray
| posted on 31/1/14 at 02:50 PM |
Is that a 'proper' full size vent though that will take the full inlet flow of a petrol pump or just a small tank vent? I have a little 3
way vent valve in my tank, but with only a 4mm bore pipe on it it will never relieve a tank while being filled. At a guess is solely reliant on the
vent it would need to pass about 40l/min.
[Edited on 31/1/14 by davidimurray]
Slimy38
| posted on 31/1/14 at 02:58 PM |
True, but it is only air rather than fuel so it can move quicker. As an example, here's one I plucked off Ebay;
http://www.ebay.co.uk/itm/221352007016
That shows the vent line you're referring to, but a much smaller bore than the main fuel pipe. That's what I would consider if I had the
same problems you have.
scutter
| posted on 31/1/14 at 03:58 PM |
I don't think the vent will help, don't most pumps work by sensing an increase in liquid level.
Our cars are effected by the fuel hitting the bend in the filler hose and effecting the mechanism.
Regards Dan.
renetom
| posted on 31/1/14 at 05:24 PM |
filler
Just put it on the top
problem solved.
davidimurray
| posted on 31/1/14 at 05:32 PM |
problem solved.
But then that means I am left with the rear ALU tub with a big hole and bolt holes around it that need to be tidied up/hidden
Some interesting reading http://www.straightdope.com/columns/read/230/how-does-a-gas-pump-know-to-shut-itself-off
renetom
| posted on 31/1/14 at 05:47 PM |
Fit a grill over the hole & do one on the other side
to match, helps with the parachute effect.
  Rear Vents
steve m
| posted on 31/1/14 at 06:28 PM |
Or, stick a smaller tube inside the filler that, will go to about the top of the fuel in the tank,
you put the fuel gun into the smaller tube, and that will mean that all the other area around the smaller tube, will allow the air pressure to escape
around it, but not affecting the filling speed
Ive tried it, and it works
Biggest problem is holding the new inner tube into the filling neck, with out is slipping into the tank
But all I did was carry a small piece of rubber hose in the boot, and slip it over the fuel gun
davidimurray
| posted on 2/2/14 at 07:05 PM |
That's a cunning plan - I like it
