beaver34
| posted on 12/2/14 at 10:24 PM |
Vented side panels
Show us yours!
Also how you did it and what's best to cut the alloy with, after doing mine next month
Not Anumber
| posted on 12/2/14 at 11:53 PM |
MKs have a huge gap round the suspenson beween the nose cone and side panel. This wasnt great in wet conditions when i had a distributor ignition (but
fine now with megajolt) but it does allow the hot airflow from the rad to exit. I havent vented any further back from there as the heat from the
exhaust exits round the gearbox to the rear and is not an issue.
[Edited on 12/2/2014 by Not Anumber]
beaver34
| posted on 13/2/14 at 08:00 AM |
i have alot more heat that a stock car inside and need to get it out
by all accounts the slim transmission tunnel is not ideal for dispensing of heat
samjc
| posted on 13/2/14 at 10:16 AM |
Not fancy wide/flared side pannels. Thats my plan after iva.
StrikerChris
| posted on 13/2/14 at 10:19 AM |
Hi
I cut most of mine with a circular saw as most of the alu was straight cuts. To form the shape for the vents I made abit of a buck out of mdf
clamped the rough sized panel to it and beat it around it. Peened the sharp edges off around the mouth of the vent and trimmed the excess off.
Matt21
| posted on 13/2/14 at 11:07 AM |
Cut some holes in you're bulk head, might aswell have the warm air blowing on your rather than getting wasted ey
beaver34
| posted on 13/2/14 at 11:43 AM |
yes thats what i mean
Ben_Copeland
| posted on 13/2/14 at 01:03 PM |
  Side Panel Flare
This is what I did, tho mine is fibreglass. I cut down the panel and then stretched it out an inch. I was lucky that the side panels had 2 inch
returns top and bottom so it was easy. I couldn't be bothered to recut all the wishbone holes in another panel
I plan to mesh the hole so it looks tidier.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
jacko
| posted on 13/2/14 at 04:59 PM |
Yes good idea and have the flames burn you if there is a fire under the bonnet
Maybe not such a good idea
yellowcab
| posted on 13/2/14 at 05:05 PM |
I'm sure you don't need to see any more pics of my car, but here is one anyway…
Made from 2mm ally, however will be replaced soon with dibond as its far lighter
renetom
| posted on 13/2/14 at 05:22 PM |
vents
Hi
We did this on both sides of the bonnet
Works fine, less work & only in my opinion
Looks better.
  Bonnet Vents both sides
good luck
scutter
| posted on 13/2/14 at 07:19 PM |
Sorry to jump in on this thread, but do people just use a single flared side panel or do they add a second stressed skin underneath?
Thanks Dan.
yellowcab
| posted on 13/2/14 at 07:27 PM |
The problem with just cutting the original fibreglass, and pulling it wider - is that all the lines of the car go squewiff… and provides no
overlap…
Add a second panel, allows you to join where the bonnet line is, and also provides you with a little overlap of around 5 inches
samjc
| posted on 16/2/14 at 12:41 PM |
Anyone know if its iva friendly to have side pannels like yellowcabs as dont want to fail on something like that. I dont mind fitting trim that my fly
off on the way back from iva but would it fail in general ?
| posted on 16/2/14 at 12:49 PM |
How about boxing the rad in and exiting the air out the top of the nose cone?
beaver34
| posted on 16/2/14 at 04:05 PM |
Ive no room for bonnet vents
black fingernail
| posted on 16/2/14 at 04:44 PM |
I have just changed the left front side panel to incorporate a vent. I just made a panel 1" bigger at the bulkhead end so it bulges out a bit. I
used 1.5mm ally, and I cut it with a jig saw and a hole saw. The pics from start to finish are on my photo archive.
beaver34
| posted on 16/2/14 at 04:52 PM |
has anyone noticed a drop in temps at all?
