AndyW
posted on 6/7/14 at 10:12 AM |
Exhaust wrap?
Hi all,
In order to reduce under bonnet temps is it worth wrapping the exhaust manifold. I have heard on another forum very heated arguments as to the
benefits or not.
Thoughts please
posted on 6/7/14 at 10:42 AM |
I wrapped mine due to running problems when stuck in traffic on a hot day even with vents in the bonnet and nose, suspect the fuel was vaporising . I
have no problems now and due to the low annual mileage I think it was worth doing.If I have problems in the future I suspect I will still wrap the
exhaust
twybrow
posted on 6/7/14 at 10:49 AM |
The reason I suspect for the mixed reports you have heard, is that some people say that it traps moisture next to the exhaust, and in time, this can
lead to rust. Well on my fully stainless system, that has never been an issue. The wrap does deteriorate over time, so by the time it fell off (2 1/2
years after putting it on) there was no ill effect to the zorst. It certainly lowered my under bonnet temperatures, so if you are having issues with
this, then I would say it is worth doing. Just take your time to make sure you do a good job, as a loose wrap will do nothing but create hot spots and
then fall off....
motorcycle_mayhem
posted on 6/7/14 at 11:24 AM |
It is essential on my Riot, mid engine, manifold behind the firewall.
If I do not wrap the exhaust, the engine bay temperatures reach dangerous levels.
whitestu
posted on 6/7/14 at 11:34 AM |
I thought the issues were that any unwrapped areas get much hotter and so can lead to fractures if you miss a bit.
Could be wrong though.
Mine isn't wrapped and I've never had any problems with temp.
Stu
matt5964
posted on 6/7/14 at 11:40 AM |
with the welds on an exhaust being the weakest point and also the part getting the hottest, some think that wrapping will over heat them and shorten
the life of your headers, horses for courses really depends what you need them to be wrapped for if your bay is getting far too hot then wrap them as
the consequences may out way having to get a set of headers replace.
We were going to before we got the Simpson exhaust made as our bay got really hot but after the primary's and secondary's were made from
larger tubing and all the same length we get no hot spots and the gasses flow much more efficient. so now even with 50+Bhp more than we used to have
the bay temp is lower and I feel we don't now need to look at wrapping to reduce it.
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
43655
posted on 6/7/14 at 03:02 PM |
not so locost, but getting the manifold ceramic coated is supposed to be better.
johnwilders
posted on 6/7/14 at 06:12 PM |
I wrapped mine back to the can and it does help with under bonnet temp, it also helps stop you branding yourself for life if you touch it with any
uncovered flesh the only downside is it tends to move the heat further along the exhaust and now the can gets incredibly hot.
coyoteboy
posted on 6/7/14 at 08:08 PM |
Well worth doing IMO. The only time it will trap moisture is if the car sits fr extended periods outside. Unwrapped bits don't get hotter, the
wrapped bits are hotter. Depending on your material you could embrittled sections but personally found that since my exhaust gets full-on cherry red
anyway until the bottom of the downpipe, its already way up in the danger region lol. Never failed me, wrapped the full length of my gt4 from manifold
(can't wrap it as its a cast log) all the way back to back box.
Reduces gas density, certainly changes engine note a bit when really hot. Stopped me baking my alternator, rad and sump.
haz87
posted on 7/7/14 at 09:51 AM |
Run it for years and years and never had any issue. Mild steel I'd be a bit more wary of for trapping moisture, but stainless its not shown to
be an issue for me (*touches wood*).
Yes the wrap does break down but buy quality rather than £10 for 1000ft ebay bargains and it lasts while
neilp1
posted on 9/7/14 at 09:18 PM |
Whats the best wrap to buy and where from. Locost of course
edthedrummer
posted on 10/7/14 at 06:18 AM |
If your not aware, a little tip when wrapping,
Keep the roll in a bucket of water below the pipes your wrapping, it softens the wrap making it more flexible, and generally makes life so much
easier. Also keeps the dust down which is a massive bonus on some wraps. Being soaking wet too, each time you overlap it tends to cling to the other
part as well meaning it doesn't unwind itself so easily half way through!
matt5964
posted on 10/7/14 at 07:00 AM |
DEI Titanium is better than most, failing that any titanium wrap
