Author: Subject: Raising bonnet
donn006
posted on 19/8/14 at 11:50 PM Reply With Quote
Raising bonnet
Hi everyone I'm looking for a couple of strips of plastic or alloy to raise my nose cone and my bonnet from the chassis as the bonnet is touching my cambelt ,I'm looking for about 2x 1.5 metres long and about 30 mm width and 15-18 mm thick I've tried every ware from BBQ ,wicks and even a plastics place but no joy
Macbeast
posted on 20/8/14 at 05:10 AM Reply With Quote
Rectangular section plastic electrical cable trunking ?
INDY BIRD
posted on 20/8/14 at 05:50 AM Reply With Quote
No help with the trim but is lowering the engine and Option if only 15mm ? Or is this too much?
Failing that.poss use wood strip to raise it and cover it in 3m di noc carbon effect vynl
Cheers Sean
mcerd1
posted on 20/8/14 at 07:35 AM Reply With Quote
what about a bonnet scoop - that's what most folk do in this situation
like this one for example:
Matt21
posted on 22/8/14 at 12:49 AM Reply With Quote
could you not use some alu box section?
1"' x 1/2"', 1.1/2"'x 3/4"', 2"' x 1"',Aluminium Rectangular Tube / Box Section
£29 for a 3m length of 1.0" x 0.5"
