luke2152
| posted on 8/10/14 at 09:30 AM |
attaching rear wings
What is the typical method of attaching read cycle wings (grp to aluminium)? Im thinking rough up the two opposing surfaces, sikaflex or similar and
then just 4 or 5 pop rivets to secure until glue dries. Good idea?
loggyboy
| posted on 8/10/14 at 09:42 AM |
I'd want mine removable for easy servicing/replacement etc.
Rivnuts and bolts with nice big spreader washers and a either some stick on rubber seal to 'water proof' or a very sparing application of
a basic sealant (that will tear/remove easily if pulled).
Mistral Motorsport
whitestu
| posted on 8/10/14 at 09:49 AM |
Mine are attached with rivnuts / nuts and bolts and large washers as well.
40inches
| posted on 8/10/14 at 10:22 AM |
And use Tadpole Trim to seal and neaten the join.
Barkalarr
| posted on 8/10/14 at 10:51 AM |
I've got plastic number plate bolts on mine incase they get clipped buy another exuberant driver
johnnybizzle1986
| posted on 8/10/14 at 11:40 AM |
M6 bolt and nylocs, with tadpole edge trim
regards JB
steve m
| posted on 8/10/14 at 12:08 PM |
"Hi,
regards JB"
+1
luke2152
| posted on 8/10/14 at 12:44 PM |
Fair one I didn't really consider the need to regularly remove them. Are you using flush mounted rivnuts of some sort as I think mine would
stick out a quite far
b3ngy
| posted on 8/10/14 at 12:53 PM |
Yep same here, combination of m6 bolts/nylocs/rivnuts and some tadpole trim. Very easy to remove if need be.
ReMan
| posted on 8/10/14 at 01:27 PM |
Me neither.
Mine are just fitted with peel rivets (pop rivets)and washers where needed
www.plusnine.co.uk
