Author: Subject: Making new doors for a 7
madteg
posted on 12/11/14 at 09:19 PM Reply With Quote
Going to make some leather over steel doors for my 7. Anybody got any pointers and pictures. Kev.
Andybarbet
posted on 12/11/14 at 09:53 PM Reply With Quote
I've got one westfield door here, seems to be roughly a 1" x 1/4" welded frame inside the vinyl.
Probably not much help but you never know.
Andybarbet
posted on 12/11/14 at 10:35 PM Reply With Quote
Just had a quick look in the garage, the frame seems more like 3/4" x 1/8".
It seems that the vinyl is then sewn over the framework.
Did you get any further on the hardtop that you were making ?
[Edited on 12/11/14 by Andybarbet]
madteg
posted on 12/11/14 at 10:39 PM Reply With Quote
Finished the hardtop, looked great but could not stand the noise inside the cab. Cannot believe how loud it was. Ended up throwing it in the skip.
myke pocock
posted on 12/11/14 at 11:00 PM Reply With Quote
Would be interested to know how you sew over an 1/8" thick piece of steel strip as I want to make doors as well.
Andybarbet
posted on 12/11/14 at 11:07 PM Reply With Quote
I picked up the westfield door for £5 purely to see how it's made, i plan to make 2 when my cars finished but yes, ive no idea how they sew it. I reckon it will probably be easier to fit my screen in a position that i can use the standard westfield doors if i have the length from rear arch to screen.
screens 3
screens 3
Picture stolen from another locost builder.
The frame runs completely around the edge, one bar across the middle below the window section, the whole thing then has vinyl sewn each side of the framework.
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 13/11/14 at 07:39 AM Reply With Quote
The newer Westfield doors will fit the best. I put some of these on my MK. Caterham doors are way too short - been thre tried them.
The Westfield door in the picture above is the older design - the newer design have a curved rear edge.
whitestu
posted on 13/11/14 at 07:59 AM Reply With Quote
I made mine out of sheets of polycarbonate riveted to aluminium bar for a bit more strength. I had some vinyl / steel ones but they didn't look great and were way too heavy.
anthony1
posted on 13/11/14 at 12:27 PM Reply With Quote
Making doors....
If you look in my photo archive , you can see the doors I made for my MK ......I made these from fibre glass , with polycarbonate for the tops. I made a mould from 5mm ply/ filler etc then moulded the glass fibre onto that.
