Author: Subject: Doors...
Dave Bailey
posted on 7/6/15 at 08:16 PM Reply With Quote
Doors...
Does anyone have a set of Caterham doors and would be prepared to draw a template of one so that I can see if they will fit my Luego? I would like to use Caterham doors because of the bulge in them gives a bit bigger space in the cockpit...
Dave B
Andybarbet
posted on 7/6/15 at 09:08 PM Reply With Quote
I'm pretty sure the caterham ones are way too short for a velocity.
I have one westfield side screen that I picked up for £5 just to check the size, it looks like it's the right length depending on the windscreen position.
I'm not sure if westfield do one with a bulge though ? I could probably sketch some measurements if you need me to.
Dave Bailey
posted on 7/6/15 at 09:26 PM Reply With Quote
Andy great yes please if you get time... Thanks...
Dave B
Andybarbet
posted on 8/6/15 at 06:42 AM Reply With Quote
Hi dave,
I will try my best to sort it this evening for you.
Dave Bailey
posted on 8/6/15 at 10:12 AM Reply With Quote
thanks....
Dave B
40inches
posted on 8/6/15 at 10:19 AM Reply With Quote
I fitted Caterham half doors to the Indy, Caterhams are tiny cars! I extended them to fit, but am on the look out for some that are bigger.
Andybarbet
posted on 8/6/15 at 08:25 PM Reply With Quote
Here you go dave, if you have a big bit of card it should make sense.
measurements
measurements
westfield sidescreen
The window is about 6cm's in from the edges & there is a good 2cm's all round the edge of the whole sidescreen that is just vinyl so it's got some flex, basically the metal frame is 2cm's in from the edges if that makes sense.
Good luck.
[Edited on 8/6/15 by Andybarbet]
Dave Bailey
posted on 9/6/15 at 11:23 AM Reply With Quote
Andy.. thank you so much... Nice little job for me tonight :-)
Dave B
Chris_Xtreme
posted on 9/6/15 at 01:13 PM Reply With Quote
the quantum xtreme also has elbow bulges on the doors and is a bigger car... let me know if you want the details.
Andybarbet
posted on 9/6/15 at 07:29 PM Reply With Quote
I've always thought that quantum nailed it with their side screens, they look spot on.
It would be interesting to see if they would fit a velocity.
Enjoy the 'blue peter' project dave, let us know how they look for size, ive only tried it on my bare chassis with the scuttle placed roughly in position.
Dave Bailey
posted on 9/6/15 at 07:38 PM Reply With Quote
Andy I need to get some cardboard tomorrow but I have just had a quick measure and it looks pretty good.
I'll let you know how it goes...
Thanks again....
Dave B
