AntonUK
posted on 22/6/15 at 12:31 PM |
Thickness to Mount bonnet catches
I need to mount the aero catches for securing the bonnet on the Ginetta. The existing pins are fitted to a 3mm plate, but the pins are too close to
the scuttle to use aerocatches so it needs cutting and re-welding (or bolting if using Ali)
What thickness material (ali or steel) should I be using for bonnet pin mounts? 3mm steel seems overkill?
Build Photos Here
ken555
posted on 22/6/15 at 02:52 PM |
I went with 3mm Ali
[Edited on 22-6-15 by ken555]
