Author: Subject: Shaping mesh to fill vents
Matt21
posted on 29/9/15 at 04:25 PM Reply With Quote
After cutting the holes in my bonnet for vents I still need to fit the mesh.
I was planning on just sticking the mesh to the inside of the bonnet.
However now I'm thinking of shaping it slightly so that on the outside the mesh sits flush with the outside of the body work.
Like this...
The mesh is this style and made from aluminium
has anyone shaped that style mesh into the shape I'm after before?
I think using a tea towel and gently patting the mesh through the vent hole would do it?
any better ideas?
Slimy38
posted on 29/9/15 at 05:04 PM Reply With Quote
I wouldn't use the bonnet itself as a former, it wouldn't take much to crack it. Mark the same hole in a piece of wood, cut it out then use the wood to form it. If you cut the centre out, then cut the middle piece down a bit, you could use it to push the mesh through, then hammer the edges of the mesh flat to form the fixing lip.
Ben_Copeland
posted on 29/9/15 at 05:35 PM Reply With Quote
Use mdf/ply as a former
Ben
Locost Map on Google Maps
Enter Your Details Here
rash12
posted on 29/9/15 at 05:57 PM Reply With Quote
as above i used ply cut to shape and chamfered round the edges then pressed into shape leaving a flange type lip to bond on with tiger seal etc
bi22le
posted on 29/9/15 at 06:53 PM Reply With Quote
It very easily deforms as the little ali strips twist so dont be tempted to use a mallet of anything too hard. Work on the back edge and on hidden parts as much as possible.
Also be aware that that type of ali is actually quite restrictive to air in most orientations. It also looks visually different in all 4 directions, even if the diamond shapes are all of the same orientation so tripple check the little strips are at the same angle and layered up in the same orientation or the vents wont visually match.
Please read my ring story:
Matt21
posted on 29/9/15 at 07:46 PM Reply With Quote
good point bizzle!
thanks guys, ill try it out when I get chance
