Author: Subject: Exhaust question
rm0rgan
posted on 30/9/15 at 07:16 PM Reply With Quote
Exhaust question
Hello. I've replaced the bike can I had on my MK Indy with a Wunoff exhaust can and have a question...
As the new can is longer by a few inches do I need to cut the excess exhaust pipe down so it just enters the new exhaust chamber or can I simply slide the excess into the exhaust.
For now I've slid the excess in and it seems fine and revs ok etc - it's quite a bit quieter and deeper in tone than the bike can but wondered if I should cut the pipe down in case I'm restricting it at all.
Thoughts appreciated :-)
[Edited on 30/9/15 by rm0rgan]
Sigs are uncool.
bi22le
posted on 30/9/15 at 09:36 PM Reply With Quote
A quick calculation assuming you have a 50mm dia exhaust going towards the silencer, and that all wall thicknesses are 1mm says that the reduction in area is around 8%.
It may rev fine but its when the engine is under strain you will notice the difference. Give it a whirl and see what happens. I know that most silences slide over the collector tube.
Please read my ring story:
snapper
posted on 1/10/15 at 05:44 AM Reply With Quote
The only thing it will do is increase the noise as you will be blocking some of the perforated price inside the can
I eat to survive
I drink to forget
907
posted on 1/10/15 at 06:26 AM Reply With Quote
It's a bit like buying an eight bedroom mansion and only living in two of the rooms.
Paul: ^^^ What's a "perforated price inside a can"?
Just wondered if I should be fitting them.
Paul G
rm0rgan
posted on 1/10/15 at 06:47 AM Reply With Quote
Thanks. Bi22ie I did have a look at other people's silencers and it seems hit and miss as to whether they slid over or under the collector and in some ways it makes sense for it slide in as the design looks like it's wider at the start so as to 'receive' the pipe and then the bracket clamps it down to seal it. It's also how it was on the car when I bought it and the same set up as was on my other cars.
That said, it's the excess I'm most interested in as I thought like 907 suggests, would I be losing some noise reduction (but I actually find it quieter than what I had previously so either I'm already deaf or the bike can was madly loud which it did feel a tad too loud to me).
I'll give it a bit of time to see whether I notice any change in performance. A quick blast yesterday didn't seem to register any drop in performance but I only went for a quick blast.
I might cut the excess pipe off but leave it mounted the way it is as just to make it easier to remove when I want to repack it.
Sigs are uncool.
