Author: Subject: duratec rwd
bug1
posted on 8/10/15 at 06:44 PM Reply With Quote
duratec rwd
Hi I want to fit a 2.0l duratec in my car what parts would I need to fit it to a type 9 gearbox I know I need to mod/change the bell housing and can I also fit a hydraulic release bearing? also will I need to run a cat?
[Edited on 8/10/15 by bug1]
davidimurray
posted on 8/10/15 at 09:21 PM Reply With Quote
Lots to do to keep you busy - http://www.locostbuilders.co.uk/viewthread.php?tid=192871
Cat or not will depend if it is already registered and if so emissions will be whatever it is currently - so if you've got a cat you still need one, if not then you won't need one.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
bug1
posted on 11/10/15 at 08:54 AM Reply With Quote
thanks for that just what I needed very informative.
baldthreads
posted on 23/10/15 at 07:57 PM Reply With Quote
water rail
throttle body's and management
sump
flywheel, clutch and bell housing
alternator
exhaust manifold
etc
