tigertom
posted on 15/12/04 at 04:49 PM |
Fitting seats.
Going to fit seats and harness's over the chrissy hols and just wanted to check before doing so.I was going to use 4 bolts fitted with penny
washers,through the bottom of the seats(intatrim) to fix them to 2 pieces of box section which run the length of the car.Will this satisfy Mr sva?.
posted on 15/12/04 at 05:06 PM |
Most likely - we have ours on aluminium tubes (upright) secured to flat steel braces across the floor by means of high tensile bolts. Ours passed...
good luck with SVA
mandbsheldon
posted on 15/12/04 at 05:09 PM |
SVA
Should pass on the seats, but if that's your car in the picture, the front wheel arches don't look like they cover all of the rims.
Leigh.
