sgraber
posted on 16/12/04 at 01:01 AM |
Plug final surfacing
Is this the poo (I didn't say POO btw!) to buy to cover my plug before final sanding?
Duratec Gray Surfacing Primer - Perfect for Plug Finishing and Hiding Repairs
http://www.fibreglast.com/showproducts-category-category-22.html#12
Or is there something else that is better?
I looked for a product called DuraBuild, but AFAIK it's a UK only product? (I'm USA based)
Alan B. used a home improvement product called Kilz hi-fill primer and it seemed to work ok, but is this Duratec really special?
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
white130d
posted on 16/12/04 at 01:30 AM |
Featherfill
Mr. G. I used to use stuff called Featherfill epoxy primer, Hi build and really stinky stuff. I use Nason (dupont)Urethane primer now that will hide
80 grit scratches...
David.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
Donners90
posted on 16/12/04 at 11:05 AM |
Came across this the other day, don't know if it's much use as you're in the US, but here it is anyway!!
http://www.bodyshopwarehouse.co.uk/
stephen_gusterson
posted on 16/12/04 at 03:09 PM |
i just used ordinary body filler - then went over it after sanding with a water based varnish to seal it.
as always, its on my site
atb
steve
[Edited on 16/12/04 by stephen_gusterson]
Volvorsport
posted on 16/12/04 at 04:25 PM |
i use , upol reface - a high build polyester based paint , its thick so you can brush it on - i recomend you spray it on , its cheapish aswell , and
can be treated like normal paint - ie it can be made to shine quite well .
that picture has a blue marker coat prior to sanding .
[Edited on 16/12/04 by Volvorsport]
www.dbsmotorsport.co.uk
getting dirty under a bus
Hugh Paterson
posted on 16/12/04 at 07:17 PM |
Steve will have a decko at the spec sheet tomorrow, I suspect that duarbuild is manufactured in the states as its supplied in U.S. Gallons, if i find
out where will let u know tomorrow. What u paying for the upol, durabuild aint cheap??
Shug
Hugh Paterson
posted on 16/12/04 at 07:22 PM |
Ho Ho HO methink's yon Duratec is the same stuff with a different label to the tins we get supplied over here, bluddy dummy should have looked
at the link first
Shug.
sgraber
posted on 16/12/04 at 07:30 PM |
at the link first
Shug.
And I think I get it CHEAPER too! hehehehe ho ho HO!
Graber
Hugh Paterson
posted on 16/12/04 at 09:34 PM |
I hope u put too much catalyst in and you bung up yer spray gun hoo hoo (been there), less said bout that the better
Shug.
