40inches
| posted on 11/5/16 at 11:38 AM |
Side screens
An interesting article on making side screens, this is on a DAX Rush, but applies to any 7.
http://www.hoverd.org/Tim/Dax/driving-body-0206a.html
Bluemoon
| posted on 11/5/16 at 12:45 PM |
Very bad photo:
But did something similar..
Dan
chris
| posted on 11/5/16 at 06:53 PM |
mine look very similar to the last photo but mine are made from a single piece of polycarb and then I just covered the bottom half with leatherette
and made two latches on each door that hook on the side bodywork 11/5/16 by chris]
[Edited on 11/5/16 by chris]
Bluemoon
| posted on 12/5/16 at 06:19 AM |
Nice idea, considered it for mine but needed a lot of curves to get elbow hole and the polycarbonate also needed to be held curved slightly to make
room (not clear on the photo), the central aluminium strip provides the rigidity needed to do this...
It was to large to form in the domestic oven
Dan
chris
| posted on 12/5/16 at 08:23 AM |
yes had to form them a bit to curve into the corner of the scuttle on my first drive with the doors on got to thirty miles an hour and both doors
flopped inwards so a quick rethink and i added some steel strengthening one strip across the middle and folded it into the leatherette and now can go
flat out
just used a hot air gun to form it
[Edited on 12/5/16 by chris]
Bluemoon
| posted on 12/5/16 at 08:31 AM |
flat out
Yep, had that issue as well there appears to be quite a high pressure zone just behind the screen.. Limited speed to 50mph ;( They would
"Pop" inside out above this speed ... Aluminum strip fixed this, still flap a bit at the back but o.k.
Dan
chris
| posted on 12/5/16 at 08:34 AM |
mine are ok at the back because they go right back to the roll bar so dont flop in and because they go that far back reduces the buffeting to almost
nothing
mk1storm
| posted on 12/5/16 at 11:17 AM |
Yeah I took some of the advice from that and used it to make mine, which I documented here if you're interested:
http://forum.daxsportingclub.com/phpBB3/viewtopic.php?f=35&t=5478&hilit=doors
Bluemoon
| posted on 12/5/16 at 11:56 AM |
How good are the helicopter vents, do you get some ventilation?
I find even the surrey top (half hood) get's a bit warm on a long run may be worth fitting...
Dan
mk1storm
| posted on 12/5/16 at 12:20 PM |
Dan
I added them as the old 2nd hand doors I got had them and thought I'd better put some sort of vent in, but I try to leave the hood down as much
as I can, so honestly speaking I've never used them in anger so difficult to tell!
They do let some air in for sure...
The only times the hood's been up have been:
1) If I've parked it somewhere - ie not driving it
2) When getting caught out in a shower on the way to/from somewhere but so far I've been lucky enough not to have needed to put it up long
enough to really test it out.
3) When it's really cold and the missus starts complaining on a long drive! and then as it's not warm the vents aren't needed
anyway...
Sorry, not very useful but I might try them out properly next time I'm out in the car... just to satisfy my own curiosity now!
