AntonUK
| posted on 11/5/16 at 02:13 PM |
Roof?
Hi All,
After being caught out a couple of times in the Ginetta, Its time I made a simple roof for it.
I dont really want to fit press studs into the bodywork, so plan to use plastic webbing buckles over the roll cage.
Couple of quick questions?
What material do people use, at a guess it isn't just plain old vinyl off the shelf of the local dunelm?
Will the plastic buckles be sufficient to hold?
Any tips or tricks to getting it all aligned, sewn/glued up?
Regards
Anthony
Build Photos Here
swanny
| posted on 11/5/16 at 02:31 PM |
have a look here, I'll be making one to go over my cage at some point
link one
link 2
Bluemoon
| posted on 11/5/16 at 03:27 PM |
If your doing it yourself for fabric advice and supply talk to:
Profabrics.
Martrim.
My attempt:
Used some very cheap fabric from Profabric, more of a trial at the min but works well enough.
You might wish to use a hoop or similar that follows the contour of the screen, take a look at how the DAX rush and MK hoods are fitted to the screen
might give you an idea.. These do not need poppers..
These videos may help;
http://www.locostbuilders.co.uk/viewthread.php?tid=145222
Dan
[Edited on 11/5/16 by Bluemoon]
LBMEFM
| posted on 12/5/16 at 04:03 AM |
If you are near the coast go to a ships chandler, I had a tonneau cover made up for my MGB and bits and pieces for my 7, they are used to making
covers and things for boats. and use marine grade PVC/canvas. If you are inland marquee companies can do the same thing, I had new windows sewn into a
hood. In both cases I found the cost very reasonable, they made them exactly to my spec and as they have the experience and tools the result was a far
better job they I could have done. If you just want the material they will also supply that..
[Edited on 12/5/16 by LBMEFM]
swanny
| posted on 12/5/16 at 09:32 AM |
blue moon, did you put a rod through the top of your half doors? i've seen a few that do, and presume it stops it flapping about?
Profabrics.
Martrim.
My attempt:
Dan
swanny
| posted on 12/5/16 at 09:35 AM |
also has anyone put a roof on a car with a full cage?
AntonUK
| posted on 12/5/16 at 01:48 PM |
Im sure its been done, sure hope its possible as thats what Im aiming for.
Build Photos Here
Bluemoon
| posted on 12/5/16 at 01:50 PM |
^^ Possible just getting in and out might become more difficult, bad enough with roof installed and no cage in a 7 as no real doors...
[Edited on 12/5/16 by Bluemoon]
AntonUK
| posted on 12/5/16 at 03:25 PM |
Thats fine the Ginetta has proper doors
Build Photos Here
