MNR Vortx 2009
After much deliberation, here goes:
2009 Mnr Vortx Inboard
Currently 2600 miles since sva in feb 2009 Need to confirm this but roughly right
2006 R1 engine which had 6k on when installed.
Sump baffle and Barnet clutch springs fitted
Modified for a breather can off the old AIS ports (goodrich hoses and rally design can)
All screwed fittings rather than push on, not a jubilee clip in sight
Power commander 3 usb
Pipercross px600 air box with k&n enclosed filter w/ silicone hoses to infront of the rad. This wasnt cheap, nearly £500 worth of bits alone
All silicon cooling hoses polo radiator.
Two piece prop with trt rear section.
Quaffe reverse box with breather and proper oil Again goodrich hose and JIC fittings
Mnr exhaust headers and can
Intertrim oddessy seats
Savage switches
Willans harnesses w/ alloy buckles 3 inch straps (£500)- dated to 2014
Mnr side impact bars
Digidash 2
Mnr column mounted paddle shift
Mnr aero screen
Race tech mirrors
MOMO Wheel & Bell QR Boss just fitted this year
Sierra 3.38 diff and shafts
Raceleda alloy uprights
Radeleda calipers
Team dynamics pro race 1.2 15" wheels. With toyo 888 (5mm tread on all)
Mnr lights and high level brake light
Mnr rear diffuser
Finished in kawasaki green with black aero style front arches, green with black centre rear arches. Green with black top tunnel. Carbon effect
interior panels and stone chip protectors on the rear arches.
Have got a sports cat and map for mot
Also included is a custom made tonneau cover for storage in or outside, full waterproof marine / boat covering fabric with top notch fixings.
As pictured, sports cat included but not fitted
Its an amazing car and in spotless condition. Always garaged, its as you'd expect for a car with less than 2600 miles on.
Its in a 2009 plate and says MNR on the v5.
It got everything it needed when built, as you can see from the breather and airbox - no expense spared. Has had an oil change 200 miles ago. It
doesn't need a penny spending on it - just drive it away.
I'm after £9000
The car is located in Littlehampton west sussex viewings possible but notice will be required due to work commitments. I am happy to take serious
buyers out for a passenger ride.
It is with great hesitation that I have written this advert so no time wasters please.
Please U2U me on here if interested, I will supply email or phone via U2U for interested parties.
Rob
