<<  1    2  >>
Author: Subject: Side impact protection?
posted on 31/10/16 at 10:18 PM Reply With Quote
This post was started as a result of this nasty crash - I didn't want to clutter up that discussion, so I thought I'd start one here...
The seven-style car gives pretty good driver/passenger protection from impacts in most directions apart from the area between the rear wheel and the windscreen - any impact there is likely to crush the occupant very badly, especially if the car hits a tree or post.
Has anyone had any thoughts about ways of protecting the sides, without losing the soul of a seven-style car?
Note: a side impact with a tree or post is bad in any car - a neighbour of mine was killed when the Sierra in which she was the passenger slid sideways into a tree - but is there some way of mitigating the force of an impact to reduce the damage to the occupant?
INDY BIRD
posted on 31/10/16 at 10:27 PM Reply With Quote
Did this on my mk may or may not help but still worth it, and it's not too ott in my opinion
MK INDY S2000 RR
MK INDY S2000 RR
rf900rush
posted on 31/10/16 at 10:40 PM Reply With Quote
Dax fitted , what they call Side impact bars.
DAX1
DAX1
Just glad I have never proven the function.
Sadly sold now.
The only sure way to know how save cars are is some sort of crash testing, but unfortunately this is very expensive.
Even with this, side impacts are never going to be safe , there is not much distance to reduce the 'G' force involved.
Slimy38
posted on 1/11/16 at 07:47 AM Reply With Quote
I'm planning on doing something similar to the Dax, but because it'll have a full body on it I'm hoping the side bars will be hidden inside the bodywork. Obviously with a standard seven it's a bit more difficult to have discreet protection. It'll be part of the rollcage in the same way, I just haven't quite figured out how!
I like the 'diagonal' aspect of it, to me that seems like it's likely to deflect the impact rather than try and absorb it.
motorcycle_mayhem
posted on 1/11/16 at 09:06 AM Reply With Quote
Jeremy Philips had this covered on the Riot. Some had a very safety-committee add-on looking 3-point bolted on contraption, per side. Others had a bar incorporated very nicely as part of the chassis, retaining the good looks ('good' being subjective here, but it looks good to me).
Westfield (et. al.) have full cages to achieve a good level of race protection, albeit at some visual aesthetic cost.
Ford, Vauxhall, Volvo, etc., build lovely modern cars with far more side protection than the usual 7-type. This is what you really need, I guess, if anyone is squeamish about getting hit (or hitting things).
russbost
posted on 1/11/16 at 09:24 AM Reply With Quote
It's not easy to do something that is effective & aesthetically pleasing if you're adding it in on an already built chassis, though I think the Dax side impact bars look like a good job.
If it's being done at the design stage it's relatively easy to improve side protection without losing the look of the car, just making the top chassis rail 50 x 25 instead of 25 x 25, with the wide dimension being horizontal, or a 50mm dia circular section top rail, would make a massive difference & by the time it had bodywork over would barely notice, but it does still leave the problem that the sides themselves are very low, though you could bring a bar forward from the roll hoop to the screen base, but it's not going to look pretty or be particularly easy to negotiate getting in & out
You have to remember that when the car was originally designed, there wasn't much traffic around to drive into it, (plus Colin Chapman wasn't overly know for his protection of drives!) things are somewhat different nowadays.
If you imagine the result of being hit from the side in a 7 by one of these high fronted "truck like" SUV's or 4 x 4's which seem to be all the rage with school run Mum now, it doesn't bear thinking about, I'm pretty sure all the plastic on the front of the truck would compress & disintegrate & the whole front would go straight across the cockpit of the 7, the only thing that's going to give significant protection against that sort of impact is a full cage, in which case you would simply be pushed sideways down the road as being the lighter vehicle
I guess it depends how much driver (& passenger) safety you are happy to live with or without, that case where the guy has just been jailed for 10 years cos he was looking at music on his mobile phone b4 he ploughed into the back of stationary traffic & killed 4 people brings it all home a bit - it really doesn't matter what you're driving if you get sandwiched between 2 trucks, when travelling on dual carriageways & motorways I try to avoid ever being between a pair of trucks if I possibly can - defensive driving is probably more effective than any crash protection
motorcycle_mayhem
posted on 1/11/16 at 09:36 AM Reply With Quote
As I've said before (I live on a bend, approach road to a school), I see Mum in her SUV, kids on board, driving at speed, on the phone, completely oblivious, traffic calming meaning nothing to these monster trucks. Two of them approaching from either arm of the corner usually results with carnage, daily.
She wouldn't even sense the impact your 7 would create if it got in her way.
Mind you, Mitsubishi EVOs and 7's on a trackday always looks a bit iffy too...
dinosaurjuice
posted on 1/11/16 at 09:40 AM Reply With Quote
Crash protection on all kit cars is fairly minimal... the strongest chassis in the world would just kill the driver through high deceleration of organs
I just like to think its safer than a motorbike, unless its a BMW C1....
Doctor Derek Doctors
posted on 1/11/16 at 10:12 AM Reply With Quote
The Life Taker (my old sprint car) had a side impact bar made by Caged along with the full race cage.
Thoresby TLT 2
Thoresby TLT 2
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Andy D
posted on 1/11/16 at 11:06 AM Reply With Quote
I had a relatively light sideways bump at Rockingham earlier this year, towards the end of this vid:
https://www.youtube.com/watch?v=gfauitvEMfc
When you see how far my head moves, I do wonder what would have happened if I'd hit on the other side?
Years ago I went to a gathering of Westfields for a run out. One car failed to turn up. It transpired the lad had spun his car sideways into a lamp post at relatively low speed. Minimal damage to the car, but the lad had smacked his head on the lamp post with fatal results.
posted on 1/11/16 at 11:19 AM Reply With Quote
My wife was happy when I replaced motorbikes with my Locost - it's a bit better than a bike, but not a huge amount better.
The main problem with this type of car is a big truck - they could drive straight over you.
Slimy38
posted on 1/11/16 at 12:54 PM Reply With Quote
Maybe somewhat apocryphal, the original 'rollcage' was intended to protect the engine rather than the driver as engines were considered more valuable...
sdh2903
posted on 1/11/16 at 01:00 PM Reply With Quote
I think a sideways on impact with something narrow such as a lampost or tree is always going to be bad in a 7. Even with a side bar. Lets face it you buy and drive a 7 for the driving experience not its Ncap rating.
benchmark51
posted on 1/11/16 at 03:54 PM Reply With Quote
Driving a 7 or any other lightweight car is hazardous, but this is why we do it.
Much of the fun is in the risk just like many other pastimes and we can all choose not, but we won't.
GaryM
posted on 1/11/16 at 05:12 PM Reply With Quote
Do MK Indys have welded steel plate or riveted sheet Aluminium floors?
Sam_68
posted on 1/11/16 at 05:31 PM Reply With Quote
The is a very pertinent post.
All the hip-level side impact bars in the world aren't going to help you if you headbutt the front of an SUV or a lamp post hard enough, and depending on the direction of impact, roll cages can actually worsen the scenario in a road accident.
The moral of the story is: if you're worried about personal safety, don't drive a 'Seven'.
CosKev3
posted on 1/11/16 at 05:44 PM Reply With Quote
Yeah your head is the biggest risk.
Wonder if the triangle top of that sign has hit him?
Could be what's broken the rear arch too if that's come down at speed
CosKev3
Riveted alloy floor yeah
posted on 1/11/16 at 06:12 PM Reply With Quote
I suppose the only thing that would make a difference would be a crush zone - something that would absorb the energy as it's destroyed by the impact. Not easy to fit to the side of a seven...
Sam_68
posted on 1/11/16 at 06:17 PM Reply With Quote
Fairly easy on something that resembles the Seven's progenitor, the Eleven, though (or, indeed, something like a Sylva Phoenix)... and you get much better aerodynamics as a bonus.
All you'd have to do is fill the sill mouldings with rigid foam or honeycomb material?
gremlin1234
posted on 1/11/16 at 06:20 PM Reply With Quote
or air bags, (yea I know IVA doesn't allow them for non production cars) but maybe a development of the motorbike airbag/jackets/hoods could be done
Toprivetguns
posted on 1/11/16 at 07:23 PM Reply With Quote
One big regret was not buying the full roll cage with the MK. Safety and somewhere for the roof box would of been a bonus!
Only drive as fast as your angel can fly... !
ettore bugatti
posted on 1/11/16 at 08:38 PM Reply With Quote
Googling "impact attenuator" and Hexcel should provide enough reading for this evening.
I thought FIA/MSA actually prescribe the design for the impact attenuators for some single seater classes, but I can't find it at the moment.
coyoteboy
posted on 1/11/16 at 11:22 PM Reply With Quote
Impossible to design for all impacts, but common ones, sure you can. And a strong chassis doesn't help in an impact. Impact attenuation can only help.
rm0rgan
posted on 6/11/16 at 10:09 AM Reply With Quote
This ^^^
They say it's generally the 3rd impact in an accident that kills you....the first being the vehicle collision, the second the human collision within the vehicle and the third the internal collision....this is the one when the internal organs move towards the point of impact and hit other organs and bones on the way. Even though the body may appear intact and uninjured, the squashy stuff in us like the liver, spleen, heart, brain etc. may be torn, bruised and bleed as it makes its way to the point of impact.
Most people don't know how much force a moving vehicle has but to give you an idea, a car going 40 mph into a tree has the same force as hitting the ground after falling off a 50 foot cliff. A person inside that car would hit the windscreen with the same force as hitting the ground after a fall from a five-story building - your body would be close to terminal velocity! You would need a carpet cleaner to pick you up.
Stay safe folks!
Sigs are uncool.
<<  1    2  >>
