tims31
| posted on 30/12/16 at 02:02 PM |
Rear light layout opinions please
I would like to gather the opinions of the knowledgeable LCB masses on the potenial layout for my rear lights.
I have had a play around in photoshop and come up with a few designs so please have a vote on what you prefer. These layouts have not yet been
completely designed around the IVA spec yet so may not be anything like these once I play by the rules.
Opinions please...
2up 1down
  2up1down
Large diagonal
  large-diagonal
Triangle
  triangle
TVR
  TVR style
Straight
  Straight
Build: http://www.martinsfurybuild.co.uk/
Mash
| posted on 30/12/16 at 02:39 PM |
Straight
Car looks V nice by the way
sdh2903
| posted on 30/12/16 at 02:56 PM |
Straight but a smidgen lower
bi22le
| posted on 30/12/16 at 03:28 PM |
The 1st or last one for me, if you have to go with them lights. Otherwise I would go for more modern ones.
Please read my ring story:
Matt21
| posted on 30/12/16 at 04:10 PM |
1st or last for me too
Instagram: @matt211988
Photobucket
My YouTube
Samuele
| posted on 30/12/16 at 04:15 PM |
Casually today I received the four rear lights for my Fury....
there a reason why I am so many (6 pieces)?
and request for VAT?
as regards the position I like the third photo
Kdempsie
| posted on 30/12/16 at 04:21 PM |
I'd go with option 1 but perhaps with the main lights 'smidge' lower and maybe the reverse and fogs a little closer together.
I went with a slightly different look for my lights, see attached link just for info.
https://jpsc.org.uk/forum/viewtopic.php?f=4&t=1209&start=30
adithorp
| posted on 30/12/16 at 05:17 PM |
I'd go for No1 but move the fog and reverse closer. The bit below the number plate is the flattest/squarest for the fog requirements without
having to make a plinth.
http://jpsc.org.uk/forum/
gremlin1234
| posted on 30/12/16 at 05:27 PM |
I quite like the triangle one, however, you will also require rear red reflectors,
avagolen
| posted on 30/12/16 at 09:24 PM |
Hi Martin,
Just seen this post. Interesting. I bought a similar amount of lights for my Fury.
I did not use the reversing lights as I thought it made the rear too cluttered.
I put the stop/tail and indicators as in picture 1. I then put the Fog light central below the number plate.
(I think there may be a fog light with a reversing light in the centre available now.)
For the reversing light, I put a completely different light in a suitable position. It is mounted with a single ally bracket and is held in place with
a single bolt that I drilled out for the wires to pass through.
I have to say that the reversing light is the only part that I changed on the whole car after it was on the road.
All of the lights have fibreglass plinths that ensure that all are vertical, not for IVA reasons but for aesthetics.
It was a long process to manufacture the plinths, but worth it.
HTH
Len.
snapper
| posted on 30/12/16 at 09:58 PM |
Yup I'm going first or last with a bit lower
Thank you for this I have just bought an old Fury with a busy rear end that I know needs changing
I eat to survive
I drink to forget
loggyboy
| posted on 30/12/16 at 10:36 PM |
Try a 'shop with them following the radius of the outer edge. Tail/stop at top, indicators at quadrant of radius and fog/rev horizontally
symetrical with stop/tail on bottom.
Also the same radius principle, but indicators at extreme edge then move up and in to stop/tail then fogs (in this order remember to allow for min
seperarion of fog)
Also, is the plate to scale? I've always found that kits are so small they come up much larger than you expect.
[Edited on 30-12-16 by loggyboy]
Mistral Motorsport
tims31
| posted on 30/12/16 at 11:24 PM |
quote: Originally posted by Mash
Straight
Thanks, I'm moving towards straight with a few adjustments
The lights are LED's show should give a good brightness, not really keen on the hamburger or bullseye ones.
tims31
| posted on 30/12/16 at 11:27 PM |
Yep, think I agree but will have to see how that fits in with the IVA regs, moving the stop/tail and indicator slightly lower.
tims31
| posted on 30/12/16 at 11:41 PM |
quote: Originally posted by avagolen
Hi Martin,
HTH
Len.
Hi Len,
I'll have a play with photoshop and see how it looks with the fog and reverse under the number plate but spaced apart, I like the symmetrical
look.
I have got some plinths that came with the lights but will probably cut these down so they just surround the outer edge of the light and make the
lights vertical. It is just the Fog that needs to be 90 degrees for IVA but like you say for the aesthetics too.
Found this light on CBS which I may give a try. Could easily sit under the number plate in the middle of the rear and suit for Rear fog and
reverse.
[Edited on 31/12/16 by tims31]
tims31
| posted on 30/12/16 at 11:45 PM |
seperarion of fog)
I think I understand what you mean will have a play and see what it looks like.
No the plate isn't to scale just what I thought would be about right so I could see how it worked with the lights, will take some pictures again
next week when I'm off work so I get the correct scale and use an old plate I have in the garage.
tims31
| posted on 1/1/17 at 03:40 AM |
I think the main concensus of opinion is to go with the two straight stop/tail indicator setup which I have lowered slightly and found this rear oval
fog/reverse combination on Car Builder Solutions and added that below the number plate in the middle. Also they have some small oval reflectors too
which match the shape of the fog/reverse light.
Only thing is, the fog emits red light but has a clear lens, looking in the IVA manual it just states it must emit red light so figure it will be OK
as it has the required markings on 'E' 'F' etc. Has anyone else used this lamp at IVA or used a clear lens fog light???
