Author: Subject: Side panel cutouts
jps
posted on 23/1/17 at 07:29 AM Reply With Quote
Side panel cutouts
I've sketched out a card template for the holes I need to cut in my side panel. I had intended to try to keep as much material as possible but do I just chop out the whole bit that i've shaded in the picture below?
CosKev3
posted on 23/1/17 at 07:47 AM Reply With Quote
I would guess that piece will snap off anyway if it's not got anything supporting it from behind? (Assuming it's GRP not alloy )
mcerd1
posted on 23/1/17 at 08:32 AM Reply With Quote
If you can put a decent radius in the corners (ie. drill it first, then cut it in between) then you'd have a bit more holding on to the shaded bit
then it'll probably ok as long as its fixed something behind it
big-vee-twin
posted on 23/1/17 at 01:49 PM Reply With Quote
[img] First Wishbone
First Wishbone
[/img]
http://www.triangleltd.com
