martin62
posted on 10/4/18 at 08:56 PM |
Handbrake help
Trying to fit Hand brake and cable saw a picture on here recently but cant seem to find it,any help appreciated.
posted on 11/4/18 at 08:13 AM |
What brakes and handbrake setup are you using?
Others may have used the same parts and be able to advise on how they did it.
martin62
posted on 11/4/18 at 09:06 AM |
Handbrake help
Sorry about that. I am using Sierra Handbrake and cable, just trying to figure out how to attach the cable to the Handbrake and still have have some
adjustment
Slater
posted on 11/4/18 at 10:34 AM |
Does this pic help?
Cable was cut and rejoined using 2 x U clamps. Also can adjust length with plastic nut on the outer sheath which is butted up against the rear
bulkhead. I will search for a pic of that too.
[img]
![](/galpreviews/218aug08 021.jpg) ![handbrake details 123](/gallery/218aug08 021.jpg) handbrake details 123
[/img]
ETA found the pic of the plastic nut adjuster...
[img]
![](/galpreviews/presva_feb09 006.jpg) ![handbrake adjustment 321](/gallery/presva_feb09 006.jpg) handbrake adjustment 321
[/img]
[Edited on 11-4-18 by Slater]
[img]
![](/galpreviews/presva_feb09 002.jpg) ![hb adj 1234](/gallery/presva_feb09 002.jpg) hb adj 1234
[/img]
posted on 11/4/18 at 03:20 PM |
Same setup on my MK Indy. I did shorten the cable and clamp it back together with a drilled bolt (passed SVA fine like this as well):
[Edited on 11/4/18 by nick205]
big-vee-twin
posted on 11/4/18 at 08:06 PM |
I have overall adjustment in the middle with left right balance on the two outer adjusters
[img]
![](/galpreviews/handbrake adjuster.jpg) ![Fully adjustable handbrake](/gallery/handbrake adjuster.jpg) Fully adjustable handbrake
[/img]
http://www.triangleltd.com
martin62
posted on 11/4/18 at 08:34 PM |
Thanks for all the help hope to attack it tomorrow.
Angel Acevedo
posted on 12/4/18 at 06:13 PM |
Nyloc nuts require a couple of threads showing, Not that it would matter as once the nut undoes a little the pressure on the cable is released.
A better method would be threadlock (Although I am sure considering the tidyness of your build that you did so)
posted on 13/4/18 at 08:33 AM |
You're correct nylon lock nuts should have 2-3 threads of the bolt proud of the nylon section. Probably not the best photo to have shown, but
the one that was in my archive. IIRC I fitted a shallower nylon locknut in the actual build prior to the SVA inspection.
