<<  1    2  >>
Author: Subject: Which nose cone?
Protrim
posted on 24/1/05 at 02:31 PM Reply With Quote
Which nose cone?
I'll about to order a carbon fibre nose cone from Fluke Motorsport. They have never sold any nose cone to a Locost so they couldn't tell me if I should go with the Caterham nose or the Westfield nose.
Anyone here know if the Caterham or Westifield nose will fit? I want to buy it before I start making the front suspension and so on because if there are slightly differences I can adjust during the build process.
[Edited on 24/1/05 by Protrim]
posted on 24/1/05 at 02:35 PM Reply With Quote
In my (v. limited) experience, the Caterham nose is too small for a Locost - the Westfield should be a near-perfect fit, due to the remarkable similarity in the chassis (ahem...).
Protrim
posted on 24/1/05 at 02:46 PM Reply With Quote
So with the Westfield nose I will be able to use it with small mods? I don't want to buy it if it's not for sure that I can fit it.
Mark Allanson
posted on 24/1/05 at 02:50 PM Reply With Quote
I think the pre lit west front will fit without any problems, because the locost chassis is basically a pre lit as DJ has already almost said!)
The later nosecone is a bit more complicated.... Rescued attachment Westy Front2.jpg
Mark Allanson
posted on 24/1/05 at 02:51 PM Reply With Quote
I had to make secondary frames to carry the nose which also made the ally sides very interesting to make and fit Rescued attachment WestyAdapt.jpg
locogeoff
posted on 24/1/05 at 04:33 PM Reply With Quote
If a pre lit fits then surely a cateringvan should fit as the pre lit is a pre lit because it was before the litigation that was brought about because of the similarities.
A bit of a simplistic view but, just musing
Ben_Copeland
posted on 24/1/05 at 04:41 PM Reply With Quote
My 2nd hand caterham nosecone fitted my locost book chassis just fine! Nothing major needed doing to fit it.
Ben
Locost Map on Google Maps
Enter Your Details Here
Protrim
posted on 24/1/05 at 05:46 PM Reply With Quote
Ah, now I'm worried. Someone says Caterham will not fit, someone says
Is there any way I can measure if either of the types will fit my Locost?
Liam
posted on 25/1/05 at 12:26 AM Reply With Quote
I might be missing the point, but here's what I think...
Get a fiberglass locost nosecone. It will definately fit and you save a few hundred quid at the cost of a few hundred grams. The body looks better all painted anyway imho.
Liam
Protrim
posted on 25/1/05 at 12:37 AM Reply With Quote
I will have it in carbon fibre. I'm aiming at 480kg with XE engine and more than 250hp. This will not be any ordinary Locost. I won't quit before the Caterham R500 must eat the dust. So therefore weight is important and carbon fibre is needed.
Liam
Sorry - forgot to actually be of any help.
I dont think a caterham nosecone will fit without a bit of fettling. The flange that would sit on the top chassis rails is curved on the caterham nosecone. You might have to cut away some of the inwards facing flange on the nose to allow the sides of the nosecone to pass over the chassis rails. Hope that makes sense.
The westy nose is also likely to have various bits of flange and holes/bulges where you might not want them. But both I think will be the correct width and be able to be fitted with a little work. But do you want to take a jigsaw to your £350 nosecone!
Liam
Protrim
posted on 25/1/05 at 12:39 AM Reply With Quote
I guess I might get the Westfield nose cone without any holes. And yes, I'll use a jig saw in my £350 nose cone This is a high cost project anyway The crank cost me £1250 alone...
Liam
posted on 25/1/05 at 12:44 AM Reply With Quote
Mmmm I see. But like i said that's a few hundred grams for a few hundred quid. If you have the money then that's fine I suppose, but if you're on a budget there are much better targets for weight loss than the bodywork. You should be thinking about wheels, ally uprights, ally brakes, yourself, etc etc. But maybe you've already got that covered.
Imho carbon fibre is often used to fleece money out of people who have to much of it with pointless products. So watch out and consider things carefuly is all I'm saying!
Liam
Liam
posted on 25/1/05 at 12:47 AM Reply With Quote
Ah now i really see!
Go for the carbon then! Every gram helps and all that. Wish I had funding like that! Still, making my own engine intake will be... fun!!
Liam
Protrim
posted on 25/1/05 at 12:48 AM Reply With Quote
What does the fiberglass nose cone for Locost weigh?
I'm 65kg myself The crank will be 13kg when I'm finished. Rear axle has alloy housing, gearbox has alloy housing and dogbox kit, AP Racing brakes where all components weight as low as possible, light weight battery, alloy radiator, light alternator and on and on. Yes, I've thought weight almost every place you can think about weight.
Liam
posted on 25/1/05 at 01:02 AM Reply With Quote
Hmm good question...
2.3 kg give or take a little bit according to my kitchen scales. That's for a Luego locost nosecone. 500g heavier than a fluke motorsport carbon cone at 1.8 kg according to their website.
You could machine that off your key or something But then you could do that AND have a carbon nosecone! They do look nice it has to be said. Go for it if it's worth it to you!
Just out of curiosity, if you're targetting an R500, what made you choose to put loads of work/money into an iron block engine? Oh well. Good luck anyway.
Liam
Protrim
posted on 25/1/05 at 01:09 AM Reply With Quote
Because I will use the best engine suited which are a Vauxhall XE. I can get alloy block, but for £2500 I choose to use that money on other weight saving parts. Even with an XE I'll try my best to go below 500kg.
Huh, .5kg was little for £200 extra
posted on 25/1/05 at 08:17 AM Reply With Quote
In my car one of the heaviest items is the nut holding the wheel...
Mr G
posted on 14/2/05 at 07:30 PM Reply With Quote
I don't know if others get the same feeling reading this thread but your contradicting yourself!
Originally posted by ProtrimI won't quit before the Caterham R500 must eat the dust. So therefore weight is important
Money IS an issue then as you would shell out for an alloy block @ £2500 AND spend £2500 on other weight saving parts if the Xe floats your boat that much
All the best in building your R500 beater but i'm sure that there might of been some engine options better suited from the start to get your bhp per tonne figure if your keen on weight saving!
G
Protrim
posted on 14/2/05 at 08:58 PM Reply With Quote
Thank you I'm not a dreamer, the car is being built just so I make that thing clear. There was a time I was 15 years old and dreamt about everything, but now I'm older and the car will see daylight within a year or so.
Anyway, about the engine option, yes, maybe there is engines better suited, but when you are an Vauxhall fan you build XE. And there isn't a lot of engines better suited other than motorcycle engines.
Since I've a forged crank with high quaility steel it allows me to offset grind it. That means that with custom made rods and pistons (that I would custom make anyway) I can raise it to 2238ccm and therefore achieve more than 300hp in the XE, which I by the way never has seen before.
I've also been thinking about alloy bloc instead of all the carbon fibre because the price will be about the same. And it's maybe just as easy to change some panels later than a complete bloc.
So, with a weight below 500kg and a horpsepower over 300 there won't be many cars that will go faster than my Locost with the correct nut behind the steering wheel.
The R500 can not compete with the power to weight ratio I will achieve with my Locost. And with sequential tranny and AP Racing brakes I belive I should have the theoretical victory and hopefully also prove it in practice.
Ben_Copeland
posted on 14/2/05 at 09:02 PM Reply With Quote
A friend of mine was running an XE just above 250bhp in a calibra, then into an Astra mk2.
The collets gave way in the end, apparently the cams put too much stress on them, and them gave up.
Just something to think about when getting this sort of power out of them. Dont leave anything standard lol
Ben
Protrim
posted on 14/2/05 at 09:12 PM Reply With Quote
The head will be totally renweed with solid cam followers, solid cams, bigger valves with smaller stem diameter, bronze valve steerings and on and on.It won't be many standard parts left in the engine
Ben_Copeland
posted on 14/2/05 at 09:15 PM Reply With Quote
Yep, thats what he was running... SBD didn't think there would be a problem with the collets. SO it was never brought to anyones attention that they would weaken... Can you actually get upgraded collets ?? Make them out of titanium
They ripped out of the valve grooves
Ben
Volvorsport
posted on 14/2/05 at 10:34 PM Reply With Quote
hmmm , crank cost £1250 - did you got to QED ? for a price .
Ill say this again for £1600 , i can have internals for 2.5 and capability for 500 + bhp in my engine .
as long as your happy with what youre doing .
Re: bodywork , if all you interetsted in is getting the weight down , use one layer of gel coat , 1oz CSM / 1 oz woven roving , you will not detect the difference between carbon and GRP .
And dont put any creature comforts in either !!
www.dbsmotorsport.co.uk
getting dirty under a bus
Protrim
posted on 14/2/05 at 10:51 PM Reply With Quote
The crank is a Swindon crank from an ex-rally car. Since I run a tuning shop in Norway I have good prices on most of the things I buy.
Comfort will be zero to none I guess
<<  1    2  >>
