smart51
posted on 4/2/20 at 06:40 PM |
Can this paint problem be fixed?
OK, So not car bodywork, but bodywork with car paint. I've got a problem. I'm making a bass guitar and have painted it with Halfords
rattle cans as I've had decent results in the past. I sanded it with 2000 grit paper to flatten it but (I think) went through the lacquer to
the colour coat in the middle of the picture. I thought another coat of lacquer might fix it but the area is visibly a different shade if grey. Is
there ant way to correct it without taking it all back to the colour coat and doing it again?
Paint
[Edited on 4-2-2020 by smart51]
steve m
posted on 4/2/20 at 07:48 PM |
No easy repair, just reapply the silver, a couple of coats, and then several laquer coats, no one will ever know!
r1_pete
posted on 5/2/20 at 09:12 AM |
Personally I’d leave it, new guitars look great hung in the store, but, the vogue now is more for the played and used look.
My 1978 Strat is well used and knocked about, its been re fretted, almost plays itself but has never been cosmetically refurbed etc. There is even
rust traces on the string trees....
Stratocaster
Mr Whippy
posted on 5/2/20 at 12:20 PM |
It's a different shade cos you have sanded away the metallic particles that were all aligned on the original surface and are now seeing ones
deeper down that were orientated in a random direction reflect back less light. The only fix is to spray another layer of metallic paint, then some
more lacquer, if there is no step personally I'd just add paint rather than sand it further back, I don't think it would make any
difference.
smart51
posted on 5/2/20 at 12:32 PM |
difference.
Thanks for the explanation. It makes sense now.
Will I have trouble putting a colour coat over lacquer? I hate paint reactions. Should I sand the lacquer off or just flat it back?
Mr Whippy
posted on 5/2/20 at 12:55 PM |
So long as your using all Halfords brand paints you should see no reactions. Just spray light coats and check each when dry and stop with the colour
coat as soon as it's blended. Lacquer works best with many light coats and will gradually become shinny. Leave it to cure for a couple of weeks
then use rubbing compound.
I make it a rule not to mix any brands even when they say "universal" etc. Simoniz in particular is a nightmare for reacting and their
paint will react to Halfords stuff... know this through painful experience
I did this bike all with Halfords paints, came out lovely this was after several winters use too
smart51
posted on 5/2/20 at 01:48 PM |
You got a nice finish on that bike
