craig_thomas
posted on 22/2/24 at 08:20 PM |
Haynes body panels
I’m in need of a new scuttle, bonnet and nose cone for my Haynes
Roadster. Anyone know if these parts made for a MK Indy would fit?
Mr Whippy
posted on 23/2/24 at 07:23 AM |
I have a good robin hood nosecone i can take some measurements from or you could take come measurements of you car and people can then compare it
against any spare nosecones they may have laying about.
40inches
posted on 23/2/24 at 09:32 AM |
I could take some measurements from my Indy panels, if that would be any help?
craig_thomas
posted on 23/2/24 at 09:46 AM |
Yeah that would be very handy, thanks.
40inches
posted on 23/2/24 at 10:10 AM |
Will pop into the garage this afternoon.
jps
posted on 23/2/24 at 03:07 PM |
There used to be a file somewhere with all of the Equinox body panel measurements. It may have been on here, or it may have been on the Haynes
Roadster forum - not sure if that still exists though...
Here you go: https://forums.haynes.co.uk/showthread.php?t=13563
Voucht/Sylvain is on here so he may still have them...
... And Equinox still look to exist: https://equinoxproducts.co.uk/fibreglass-moulding/store/
[Edited on 23/2/24 by jps]
40inches
posted on 23/2/24 at 03:50 PM |
Measurements for the MK:
Bonnet: scuttle width across chassis 94cm
Scuttle height at centre 27cm
Nose Cone width across chassis 68cm
Nose cone height at centre 18cm
Length at centre line 870cm
You can work out the nose cone and scuttle dimensions from these.
The scuttle is 34cm long at the chassis rails.
craig_thomas
posted on 23/2/24 at 04:23 PM |
Thanks very much.
craig_thomas
posted on 23/2/24 at 05:21 PM |
Can you tell me the scuttle width measurement dash side please.
[Edited on 23/2/24 by craig_thomas]
40inches
posted on 23/2/24 at 08:32 PM |
Will do tomorrow.
The back (dash) side of the MK scuttle lines up with the kink in the top chassis rail
40inches
posted on 24/2/24 at 01:36 PM |
Width at back approx 105cm
I have a damaged/repairable MK bonnet you can have for £25
Some more info here, about halfway down: https://www.locostbuilders.co.uk/forum/30/viewthread.php?tid=48812
