Simon
| posted on 6/2/05 at 09:34 PM |
Bodywork latest pics - what do you think?
Just thought I'd share progress with you
Car now complete from rear to gearknob!!! Scuttle needs bolting down, and all wiring thereunder needs connecting. All side panels are painted - just
bonnet and front arches left to paint. Then engine plumbing/hazards/lightbar to do (apart from bleed brakes )
Simon
[Edited on 6/2/05 by Simon]
Simon
| posted on 6/2/05 at 09:35 PM |
Oops, should've included this one too!!
omega 24 v6
| posted on 6/2/05 at 09:50 PM |
looks nice and tidy but shouldn't the fog light be to the right of th centre line of the vehicle
Mark Allanson
| posted on 6/2/05 at 10:18 PM |
What did you use for the boot lid? I ended up making mine out of ally, royal pain in the ass!
Simon
| posted on 6/2/05 at 10:27 PM |
Om,
Fog can be on centreline or to the right.
Mark
High quality ply Looks great until I open the lid
Simon
| posted on 6/2/05 at 10:39 PM |
Anywhere from centre line to the right of the vehicel is accepted.
givemethebighammer
| posted on 6/2/05 at 11:40 PM |
Looking good, however Mr SVA may not like your "V8" badge, probably best to take it off until after the test. Crazy I know every car on
the road would fail the SVA because of the badges and number plates ! I presume you also intend to turn the roll bar bolts over so you can fit nut
covers.
keep going the end is in sight...
Simon
| posted on 6/2/05 at 11:44 PM |
V8 badge is from a type approved car
SD1
If he argues, I'll pull it in front of him. After he's written out Ministers ticket, I'll stick it back on
After test, I'm going to mould it, and from mould make some out of transparent resin, put a bulb behind and use them as side repeaters!!
Simon
JohnN
| posted on 6/2/05 at 11:46 PM |
What is... and where did you get... the cover for your boot?
Is it, as it looks, black plastic 6mm thk??
JohnN
Simon
| posted on 7/2/05 at 12:02 AM |
John,
It's plywood covered with vinyl - I got it from my garage
It's mounted using cabinet hinges (which spring closed so no "lock" required).
HTH
Simon
cerbera
| posted on 7/2/05 at 07:17 AM |
Looking nice!
What make are your dials, and where did you get them from?
[Edited on 7/2/05 by cerbera]
DarrenW
| posted on 7/2/05 at 04:27 PM |
It looks very smart.
My only criticism is the back lights, i cant get away with the square trailor look. Much prefer round ones. Personal taste though and i wont be sat
behind it
ned
| posted on 7/2/05 at 04:45 PM |
think you'll find that's actually the square sprite caravan look
Ned.
beware, I've got yellow skin
