F1 Mini
posted on 16/3/05 at 12:04 AM |
Buffing up GelCoat ?
Have tried to buff my Gelcoat with little success. Have removed the flash lines, but the compound I'm using does not seem to be working very
well. I know that Gel is alot harder than normal Paint etc, but has anyone had any good tips or used any good products ?
Clive
Triton
posted on 16/3/05 at 07:55 AM |
You have to first go thru the grades of wet n dry finishing with 2000 grit or higher then the compound.....lots of work especially if the moulds are
not up to producing a good even finish.
Mark
