Humbug
| posted on 18/4/05 at 09:35 PM |
Bonnet amendment for scoop
I am going to have to increase the bonnet line for my engine somehow. I am thinking of lifting the whole of the scuttle, bonnet and nose by putting a
1" square aluminium tube along the tope of the top chassis rails, but I think I am going to need even more height.
a) where is a good place to get a scoop/bulge?
b) how good a result could you get with an aluminium sheet bulge? it seems to me that you could potentially cut a hole in the bonnet then make a scoop
with a constant slope from front to back, then bend the sides down over a round edge to get a half reasonable looking finish.
or c) how feasible would it be to make parallel 2 cuts front to back in the bonnet and raise the front of the "flap" to form the opening of
the scoop, filling in the sides with aluminimum sheet or similar? a bit like the pic below.
All suggestions gratefully received
Volvorsport
| posted on 18/4/05 at 09:40 PM |
version C
hold it apart , with some ally , and lay up fibreglass underneath , rub down and fill , make it look nice again.
www.dbsmotorsport.co.uk
getting dirty under a bus
ned
| posted on 19/4/05 at 09:17 AM |
why the hell do you need to raise the bonnet line, when it says under your avatar that you're only using a 1.4 k-series????!!!!
Ned.
beware, I've got yellow skin
Humbug
| posted on 19/4/05 at 09:26 AM |
Simple: Height of engine > height of bonnet!
The ST bodywork is quite low and a combination of keeping the engine central, the oil filter, etc. clearing the chassis rails and maintaining a
reasonable ground clearance mean "the only way is up"!
I have moved the engine back as far as it will go to use the higher part of the bonnet as much as possible, but it can't got back any further
without the clutch release arm fouling the footwell.
Ned.
ned
| posted on 19/4/05 at 01:38 PM |
i was of the impression the k-series was quite a small engine as caterham fit it under their body which is pretty low (prob what the st stuff was
originally modelled from) so how far under the chassis does the sump protrude? has the sump been chopped at all? I'm just curious..
cheers,
Ned.
Humbug
| posted on 19/4/05 at 08:19 PM |
In the interests of avoiding too much extra expense the sump hasn't been chopped - it's a standard one.
I believe a lot of Caterhams have minimal ground clearance, or a special shallow sump or replacement dry sump. I have set mine with the sump an inch
below the chassis in order to keep reasonable ground clearance...
the need to maintain alignment limits the position as well.
| posted on 19/4/05 at 09:06 PM |
hi mate.
id seriously weigh up the options of cutting the sump against cutting the bodywork! remember, both can be ball ache, but no one sees the sump! i did
my pinto sump myself. Unless the k series uses an alloy sump, its really easy to do. Whereas, myself i find bodywork terribly difficult.
Humbug
| posted on 20/4/05 at 05:42 AM |
Unfortunately the sump is alloy, like the rest of the engine
ned
| posted on 20/4/05 at 08:44 AM |
i understand what you're saying, but are you modifying the standard sump at all? the engine in a road car (assuming where you got it from) will
have been transverse and fwd, so you'd need to modify the sump to reduce/get rid of oil surge anyway surely? why not then just get it chopped at
the same time (sure you can find someone nearby/friendly garage etc that could tig it up for you if you prep'd it all yourself?!)
best of luck..
Ned.
James
| posted on 20/4/05 at 10:10 AM |
I'd agree with Ned (for once! ). It's far easier to chop the sump and drop the engine an inch or two.
Why chop up a lovely set of bodywork if you don't need to.
Have a word with the ST guys to see what they say- I can't believe there's no work around.
Good luck,
James
- Muhammad Ali
andyharding
| posted on 20/4/05 at 12:29 PM |
Chop the sump.
My modified Pinto sump still sticks down 50mm.
