Author: Subject: Ali or stainless rivets?
Hasse
posted on 31/1/03 at 06:15 PM Reply With Quote
Hello,
I´ve read that you need to use stainless steel rivets to "bond" alu to the steel tubes.
Is this true?
Any experiences from using alu rivets?
I have a welded steel floor, but everything else will be alu.
Thank´s in advance.
/Hasse
Mark Allanson
posted on 31/1/03 at 09:45 PM Reply With Quote
If you are going to use a hand riveter, you are going to get tinseenotinitis, tenosetintous, tinisinitinitis,...........really bad wrist ache, S/S rivets are hard as hell
Viper
posted on 31/1/03 at 10:10 PM Reply With Quote
go with the stainless, much better in the long run..
stephen_gusterson
posted on 31/1/03 at 11:07 PM Reply With Quote
most people seem to be using alu they are cheaper and easier to work with.
the long run only applies if you know you are gonna keep the car a long while.......
also, a lot of people use a bonding agent - like sikaflex - to help hold the alu to the frame between rivets.
atb
steve
kingr
posted on 3/2/03 at 12:46 PM Reply With Quote
I think I'll use SS rivets, the sound of 101 rivet heads jangling around in my chassis tubes would probably drive me insane. Plus I've got a air driven hydraulic riveter, so I may as well make full use of that .
Kingr
